Royce 642 homebase - 220v transformer help
Re: Royce 642 homebase - 220v transformer help
Post by The Collector »
The Royce's clock looks very similar to that of a Stalker XX homebase's. If you could maybe find one of those that's 240v, would that sort it (or am I talking out if my bottom again ;)?
ChrisMagpie
Call Sign: 26TM553
Post by ChrisMagpie »
I have an American (novelty/collectable) clock radio (with an LED display) that runs on 120v AC 60Hz. When I feed it 120v AC 50Hz, the clock radio works, but it doesn't keep the right time. It is newer than that homebase, but uses the mains frequency for time keeping! That might be a potential pitfall :(
How about using a cheap AC wall wart to supply the clock, to test?
https://www.ebay.co.uk/itm/500ma-18v-AC ... SwV4JdhK7k
3pinplug
Post by 3pinplug »
The stalker is not a bad shout i think i will look into that, not sure about the mains wall wart option as the original transformer produced two different voltages but I am noting all suggestions at present as the advice from here is always top notch. I also saw a cheap 220v transformer that gave one of the voltages now looking for a second to see if two 240v transformer will work in there , mean two msins lead but also another option. The clock can be converted from 60 to 50hz and i did find a mod for that, have it here somewhere will dig it out
cb4ever104
Post by cb4ever104 »
ChrisMagpie wrote: 19 Jun 2020, 07:54 I have an American (novelty/collectable) clock radio (with an LED display) that runs on 120v AC 60Hz. When I feed it 120v AC 50Hz, the clock radio works, but it doesn't keep the right time. It is newer than that homebase, but uses the mains frequency for time keeping! That might be a potential pitfall :(
There usually a pin on the clock IC to switch between 50 and 60hz . I did that mod on my Uniden Madison clock . Works fine now .
ChrisMagpie
Call Sign: 26TM553
Interesting you can switch the clock IC to 50Hz.
There's a video of the clock working on one, here:
https://www.youtube.com/watch?v=ELCcYdXqOhs
The middle part of the clock flashes all the time, that would be annoying!
Plan B might be to hardwire the left hand side of the clock display to read "Ch", and then repurpose the clock switches for mods :)
PeterA
Call Sign: 26TM2714
Post by PeterA »
Looking at the schematic it looks like the transformer has 3 secondary windings...
16.5VAC
19.24VAC
11.33VAC
What about contacting the likes of...
https://vvttransformers.co.uk/index.htm
Or...
http://primarywindings.com/
WANTED
Galaxy Pluto, 2100, DX88HL, President Ronald (Or Equivalent)
Cobra 148 GTL-DX
SuperStar 3900 MK1
President Adams
Cobra 148 GTL
How about taking out the damn stupid problematic pain in the arse clock and fitting in a similarly-sized frequency counter? Lol ;)
3pinplug
Post by 3pinplug »
Would have liked that but clock and channel display use same display, thwarted at the first hurdle! These designers have a lot to answer for!
theEarwigger
Call Sign: M0RZF
Post by theEarwigger »
As it looks like LEDs on the front, those odd supplies must be rectified somewhere?
Otherwise it will be down to a special transformer and great expense/time. The modern way is buck/boost/invert modules. Look at the dev kits from Texas Instruments.
-Rob
3pinplug
Post by 3pinplug »
Hi Rob
Not sure what a dev kit is, will have a search and see what texas do, thanks for the pointer.
Contacted both of the transformer contacts I was given, one reply at all but the other came back and asked for more details of the transformer which I have subsequently sent, so maybe hear something soon.
14CS06
Post by 14CS06 »
Hello
ROYCE 642, Model 1-642, SSB/AM, 40CH CB-Radio
https://www.ebay.fr/itm/ROYCE-642-Model ... Swm7JfZ4uH
Claude
