anytone at 5555 v4 feed back
gray gms
New User
New User
Call Sign: 2e0gms
Post by gray gms » 13 Feb 2020, 22:17
I have just programmed my at 5555 but when I pressed ptt I got feed back as though I was trying to use PA an all modes.
astradyne
Moderator
Moderator
Re: anytone at 5555 v4 feed back
Post by astradyne » 14 Feb 2020, 08:24
Hi.
You've set the talk back facility too high. This is creating a feedback loop between the rig speaker and the microphone. It just needs turning off or lowering in volume.
I think it's only use is for setting up the built in echo.
108EH002
Post by 108EH002 » 14 Feb 2020, 08:34
astradyne wrote:
14 Feb 2020, 08:24
Also handy for checking any replacement mic's are working.
You can talk worldwide on CB radio,
Many happen to know otherwise dx-ing test free.
27.555 USB
gray gms
New User
New User
Call Sign: 2e0gms
Post by gray gms » 19 Feb 2020, 00:10
I am using the standard mike but I can;t see how you turn the talkback volume down
astradyne
Moderator
Moderator
Post by astradyne » 19 Feb 2020, 02:15
You need to go into the menu settings and set the talk back level to zero.
gray gms
New User
New User
Call Sign: 2e0gms
Post by gray gms » 19 Feb 2020, 11:04
I can't find talk back in the menu options i have tried switching off or disabling echo. I have no success. It was working properly before I touched it.
13EL121
Call Sign: 13DA121
Post by 13EL121 » 19 Feb 2020, 19:17
It's called MON in the menu I believe... Long time ago when I had a 5555.
