SWR METER CB ( 27 Mhz ) SCHEMATIC MADE BY YOU
rooth
Post by rooth »
I didn't see a topic on this forum.
Have you made a diagram for a well-functioning CB radio SWR meter?
I am referring to an original scheme .
Re: SWR METER CB ( 27 Mhz ) SCHEMATIC MADE BY YOU
Post by ch25 »
I rather modified existing ones since they are crap.
rooth
Post by rooth »
I have a Zetagi Mod 203W 3-200 MHz that is not working properly.
After adjusting the head of the scale to 10, when I switch on the reflector, it remains to 10, it does not move at all. I checked everything, I did not cut off. The diodes are ok, the cable is the same ... I have no idea what he has .
It would help a picture from the inside if someone has the model.
That's what it looks like to me .
Post by ch25 »
No clue. Faulty switch?
Dave C
Call Sign: 27PL259
Post by Dave C »
rooth wrote: 14 Jan 2020, 19:09 I have a Zetagi Mod 203W 3-200 MHz that is not working properly.
I have just purchased a brand new Zetagi, it looks like the same one as yours, I had extremely high SWR's despite all new cable and connectors, I eventually traced the fault to a faulty soldered connection on the centre pin of the SO239 where it meets the board...
I'd certainly go over the connections if I were you Sir :thumbup:
Life is like a box of chocolates.... Usually empty when I get there.... :crazy:
Rigs: Major M588 AM FM SSB (Std), President Grant II Premium (Std), Midland Alan 78 Plus (Std), Lowe TX 40 (Std).
Twigs: Antron 99 (Std), K40 Mag, Firestick 4', Cherokee Dial A Match 4', Sirio 1000 PL Mag.
Post by The Collector »
I confess to knowing nothing about electronics, cb in general or indeed meters, but does the solder connection on the left terminal (as viewed) on the meter look like it's possibly got a hairline crack around the joint when zoomed in...or is it just my eyesight? ;)
Stronty
Post by Stronty »
ch25 wrote: 14 Jan 2020, 18:40 I rather modified existing ones since they are crap.
What would you modify on a 203w if at all?
So internal pic of an old 203w that seems to give a reasonable representation of what its intended purpose is (lets face it its no BIrd 43/ Rigexpert). not sure that helps you but at least you have a something to look at :-).
Post by ch25 »
Get 100 ohm/ proper wattage resistor, that way you could calibrate it.
Stronty
Post by Stronty »
ch25 wrote: 19 May 2020, 21:07 Get 100 ohm/ proper wattage resistor, that way you could calibrate it.
Thanks for the hint, so something along the lines of what is described here > http://www.bmarc.org/tech-corner/checki ... swr-meter/
NightProwler
Call Sign: 163TM186
Post by NightProwler »
Stronty wrote: 20 May 2020, 00:05
Thats tomorrow project for me then :thumbup:
