Hi, does anyone here have a fix for the repeater shift issue I'm having....
...so what the issue appears to be is, I can program a load of repeaters in, but for 70cm they have different offsets of course, some are +1.6 and some are +7.6.
Now, the issue is that there appears to only be ONE setting in the radio for what the shift is, so as I save a channel to memory, the one thing it will not save is the shift frequency. I have to go into the main settings to go from a +1.6 repeater to a +7.6 repeater and it actually takes a bit of time to do that.
Any ideas? Thanks.
Yaesu FT-991 repeater shift
- Call Sign: 26TM718
Shack, noun, a small building, usually made of wood or metal, that has not been built well - Oxford Dictionary
A shack (or, less often, shanty) is a type of small, often primitive shelter or dwelling - Wikipedia
Licence - British spelling
License - American spelling
Re: Yaesu FT-991 repeater shift
Ah ha, sorted!
What was the fix might help others with this problem.
