Programmation Tait 2020
Hello
I am looking for information on the programming of a Tait 2020, among other things the setting of the "bell" button to activate the relays in 1750 Mhz
Thank you for your help
cordially
Bonjour
Je recherche des informations sur la programmation d'un Tait 2020, entre autre le paramétrage du bouton "sonnette" pour activer les relais en 1750 Mhz
Merci de votre aide
Cordialement
cordially
Bonjour
Merci de votre aide
Cordialement
- Call Sign: DF2TB
Re: Programmation Tait 2020
Do you have the software?
Hello df2tb
Good evening
I am on windows 10 and I am using the T2000CPA_v3.0.0.0 program
cordially
Good evening
cordially
- Call Sign: 26DG01
Which radio version are you using? Type 1 or 2? Simplex or trunking? There isn't much you can really do with the trunking version. I'm not sure if you can prog the bell button to do 1750Hz (I assume you meant Hz not MHz) I think the best you'll be able to do is prog the zig-zag line to open sq, and use the keypad for channel numbers (if you have a keypad). The type 1's really are very basic. Nice rigs, but basic.
Sent from my GP300 using DTMF
Hello 26mb04
My model is stamped "Alcatel" and there is an alpha-numeric keyboard.
I ask the question because I saw this on another site, (http://f5jtz.free.fr/pjacquet/t2020vhf.htm) unfortunately this article dates from 2006 and its author does not respond to messages.
I therefore ask for help to carry out this manipulation
cordially
cordially
- Call Sign: 26DG01
The picture on that site is a type 2. If you have a type 2, you will need the type 2 software. It's out there, but as I've never had a type 2 I don't have the software for it. Can you read from the radio at all? If you can, you've probably got the right software.
I confirm I have a type 2 and I have the latest software update found at the bottom of the page here (https://vk6ysf.com/T2010_Programming_201912.htm)
I have access to the options (DTMF, Selcall and CCI), but I cannot modify the bell to make it a relay call.
Thanks for your help, have a nice day.
cordially
cordially
- Call Sign: 26DG01
From what I remember, the bell button can be programmed to operate a mechanical relay on one of the rear connection pins. One way to get 1750Hz might be to program a custom Selcall tone of 1750Hz with a custom duration (1 second maybe). I've done this before to get a 1750Hz tone, albeit on another radio.
Good evening
I have already tested via Selcall, without success, when at the rear pinout I have nothing about this mentioned in the documentation.
Thank you for your support
cordially
cordially
- Call Sign: DF2TB
Claude, what happens when you key the mike with the current programming? Is there something happening and does it transmit?
Andreas
Andreas
Article not read by df2tb »20 Sep 2020, 21:03
Yes no problem, everything is working correctly, I just have to configure the opening of a relay via the button "Bell" + PTT, that I can not do ....... I manage to open the relay via an application on my smartphone (SoundGenerator). Regards Claude
