HF vertical or indoor antenna
lambrettadave
Post by lambrettadave »
I was thinking about buying a HF vertical antenna as I don't have a garden and don't have much room for a long wire either
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Re: HF vertical or indoor antenna
Post by MrWeetabix »
Hi Dave, do you have any garden at all?
Do you use a radio with an ATU or Are you looking to build a singleband vertical?
26TM175. OP: Craig. QTH: Gateshead. Also 163TM175 when mobile in Wales 8)
lambrettadave
Just a back yard but it isn't very long.
The radio has a built in atu
MrWeetabix
Admin
Admin
Call Sign: 26TM175
what sort of budget do you have and how sensitive are your neighbours? considering a combination of both factors will give us an idea what your after. haha
SgtBilko302
Call Sign: 108ct302
Post by SgtBilko302 »
Hi Dave. If you have a favourite band to operate on choose an antenna that suits your needs / budget.
If it's just an HF vertical for any band, then i would recommend the Hustler 6 BTV. I used one for years and worked as far as Tasmania, Far East and the American continent. Ground mounted with a couple of wire radials.
If the bands are 18 - 30mhz save your cash and get an I-Max.
Paul.
MrWeetabix
Admin
Admin
Call Sign: 26TM175
I use an Imax for 18-20 with the tuner in the radio and get decent results.
If you just want something very budget for the lower bands then a Snowdonia 360 will get you on the air, but essentially its just a 9:1 balun bolted to the bottom of a CB silver rod (a crude description I know but just about right). You could buy/build a balun yourself, get a cheap Fibregless pole and string some wire up the middle to essential give you the same thing
This is similar to the 360 I had in mind
https://www.radioworld.co.uk/sigma-euro ... 68QAvD_BwE
Call Sign: Lemmy
Post by ch25 »
Get CG-3000, as long wire as you can. Vertical or horizontal.
That HF-X80 is just a dummy load. Most of the power is converted to heat. Don't bother.
MrWeetabix
Admin
Admin
Call Sign: 26TM175
ch25 wrote: 30 Jul 2020, 10:38 Get CG-3000, as long wire as you can. Vertical or horizontal.
That HF-X80 is just a dummy load. Don't bother.
Like I said Chris, they are just a 9:1 balun on a silver rod..... not great, but will get him on the air with an ATU if budget is an issue
personally if money is an object, try building your own ant :-)
Call Sign: Lemmy
Post by ch25 »
Advantage of CG3000 is that it makes your antenna resonant, radiating max power.
Opposite to internal ATU which just protect finals from failure, but antenna is still way out of tune.
MrWeetabix
Admin
Admin
Call Sign: 26TM175
ch25 wrote: 30 Jul 2020, 10:46 Advantage of CG3000 is that it makes your antenna resonant, radiating max power.
If he has £300 to spend then it could be an option....
https://www.ebay.co.uk/itm/114302079284
14CS06
Post by 14CS06 »
lambrettadave
Would a wire antenna be ok in the attic?
What I mean is will it work ok
Call Sign: Lemmy
Post by ch25 »
If roof is not conductive, sure. Tin roof, forget it.
lambrettadave
Attic is made up of wood and slate tiles
Call Sign: Lemmy
Post by ch25 »
Not bad. Won't work as good as in free space, but worth trying since wire is cheap.
