I own the above mentioned handheld.
I was reading the manual about setting the ctcss tone but apparently it was a option with either a ut-50 or a ut-51.
I have looked into buying either and both are available but the big question is....
Which one should I get?
Icom IC-24ET
- lambrettadave
- Call Sign: TM455
Icom IC-24ET
- Auldgeek
- Call Sign: GM0BRJ
Re: Icom IC-24ET
One is ctcss encode only, the other is both encoder & decoder (dencoder)
For amateur band repeater access, you only need the encoder but if you intend to use it elsewhere, the "dencoder" is probably best.
Auldgeek - Drew
- 14CS06
Re: Icom IC-24ET
Hello Dave
http://www.radiomanual.info/schemi/ICOM ... T_user.pdf
http://www.radiomanual.info/schemi/ICOM ... T_serv.pdf
https://www.rigpix.com/accessories/icom_ut50.htm
https://www.ebay.com/c/1100247805
https://www.ebay.com/itm/UT-51-CTCSS-BO ... SwEutev6a2
- lambrettadave
- Call Sign: TM455
Re: Icom IC-24ET
Thanks for the info I will be having a look through eBay for a ctcss board for it.
- lambrettadave
- Call Sign: TM455
Re: Icom IC-24ET
Just so you know, I have bought a ut-51 for £14 and it was delivered in good time.
I have fitted it which took about 10 minutes and is working as intended.
