Hi guys ..
Can the low power setting on the dx70th be adjusted ?
Currently it’s doing 13w and I need 12w
Is there a way of doing this ??
Alinco dx70th low power adjustment help
Re: Alinco dx70th low power adjustment help
Turn the power down on the board or use the switch inside,sounds like the radio is in the high power position.
You need to remove 7 screws from the top case,and once you have taken off the cover look for a white sliding switch inside = slide it the other way = but you might only get 5w for pressing (L)ow and 50w for when its in (H)igh ?
27.555 Usb
27.555 Usb
- listner132
For all the differance 1 watt will make its not worth the hassle fella.
listner132 wrote: ↑22 Aug 2019, 20:54 For all the differance 1 watt will make its not worth the hassle fella.
I know it’s frustrating !! But my linear will not operate if more than 12w enters it .. it’s got protection .. so 1 bloody watt !!
108EH002 wrote: ↑22 Aug 2019, 20:28 Turn the power down on the board or use the switch inside,sounds like the radio is in the high power position.
Hi
When you say turn power down on board do you mean the overall power or can I just adjust the low power setting only ?
I wonder if like other radios there is a software menu where values can be adjusted ?
I need 12w at max
I only "moved" the slider,as thats all I needed to do.No1cber wrote: ↑23 Aug 2019, 22:47108EH002 wrote: ↑22 Aug 2019, 20:28 Turn the power down on the board or use the switch inside,sounds like the radio is in the high power position.
Hi
I need 12w at max
27.555 Usb
27.555 Usb
