Feeder and losses
Ant
Call Sign: 26TM718
Feeder and losses
Post by Ant »
So, worst case scenario, UHF, so 430MHz band, what are your acceptable losses?
It's getting expensive trying to spec my losses under 1db. I've considered putting a colinear on the roof and running some cable down to where I'll be operating, I could be looking at about 15m. I've gotten hold of some decent cable with a loss spec of 0.089db/m, giving me a loss off 1.335db which I think is too much to lose.
What do you think? What kind of set up to you have?
Ranger RCI2950DX
Uniden UBC3500XLT
Baofeng UV5RC
Baofeng 888s
Re: Feeder and losses
Post by ch25 »
6dB is 1s unit
Andy
Post by Andy »
1.3 dB is about as good as you'll get with sensible coax. It's nothing really.
'SOMEONE GET ME A SAW!'
Andy.
Ant
Call Sign: 26TM718
Post by Ant »
Yeah, anything less than 1.3db for the 15m run and we're starting to look at over £5 per metre for coax.
Ranger RCI2950DX
Uniden UBC3500XLT
Baofeng UV5RC
Baofeng 888s
Andy
Post by Andy »
Anything with losses less than that will be expensive, thick, heavy and a bugger to install. You'll have to buy special connectors too. 75 ohm satellite coax is lighter and will give lower loss per metre (it's ideal for scanning), but you'll probably want to stick to 50 ohm if you are transmitting.
Andy.
