Hi Claud
Can I send it on what's up or Messenger please if you pm to me.
thanks and regards
Allan 78 plus modification
Re: Allan 78 plus modification
- 14CS06
Hello
http://wiki.kuus.eu/index.php/Alan_78_Plus
http://www.rogerk.it/sheet/cb/Alan4878PlusMulti.pdf
Claude
Claude
I have done your instruction but I can't go and do the RU and how do you know that it comes 400channel, please?
- 14CS06
Hello
Band selection
The frequency band should be selected according to the country you are currently in.
To change the frequency band, follow these steps:
1.Turn off the device.
2.Turn it on again while holding down the "AM / FM" and "SCAN" fingers. Release the buttons
and turn the "CHANNEL" button and select the desired frequency band. Press the
"AM / FM" button to end the selection .
NB! In the UK band, you can select the EC band directly by holding down the "AM / FM" key for two seconds.
NB! If a frequency band with only the FM band is selected, the "AM / FM" key can be used to reselect the last selected channel.
Frequency band table
I Italy 40 channels AM / FM 4 watts
I2 Italy 34 channels AM / FM 4 watts
D Germany 80 channels FM 4 watts / 12 channels AM 1 watt
D2 Germany 40 channels FM 4 watts / 12 channels AM 1 watt
EU Germany 40 channels FM 4 watts / 40 channels AM 1 watt
EC CEPT 40 channels FM 4 watts
E Spain 40 channels FM 4 watts / 40 channels AM 1 watt
UK England 40 channels FM 4 watts English frequencies + CEPT 40 channels FM 4 watts frequencies
Claude
Band selection
Claude
