Inverted V dipole which way up ?
- WARLOCK
- Call Sign: 26TM134
I have a inverted V dipole one of them you screw the 3/8 antenna thingeys into dose it matter which way up it is mounted as it will only be used on my scanner so no TX use , ?
Re: Inverted V dipole which way up ?
Center side up, no doubt about it.
- bigpimp347
the clue is in the name 'inverted V'
if it was a V dipole it would look like a , erm...V..
but is it's inverted then, it's erm.......not a V but an A type shape..
but both work differently, feedpoint impedance is different to that of a center fed dipole also.
- WARLOCK
Yes Mark but for scanning RX would it make any difference V or A to receiving ? was my question
- bigpimp347
as a vertical V then it is bi directional,
and an inverted V then they claim it's omni directional (not vertical though)
as pretty much everything commercial is vertical try to keep the same polarisation.
unless like me and a few mates who purposely run horizontal to avoid noise of course.
i don't think you'll receive as good as you would using a normal dipole vertical.
