Diamond MGC50 "through window" connector.
Minus1
Post by Minus1 »
Anyone tried the Diamond MGC50 "through window " connector?
It's actually a ribbon cable connected to two SO239 sockets, that would fit through the seal in a double glazed window.
Looks handy if the house is not yours and drilling holes is not an option — but it is any good?
Re: Diamond MGC50 "through window" connector.
Post by ch25 »
For RX is OK, to transmit I suggest to use RG-174 pigtail instead.
For RX you can use even satellite through window patch, no need to spend big $$
Minus1
Post by Minus1 »
Thanks, but what does "use even satellite through window patch" mean?
What is a "window patch"?
Post by ch25 »
Satellite coax window patch.
No idea how they name it in UK.
Looks like that:
Minus1
Post by Minus1 »
Thanks. Everyone I've found seems to use their own description, I shall give one a try.
