coax for scanning ???
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
I am putting a antenna up for scanning , I have a lot of unused satalite tv coax would this be ok to use on my scanning antenna i will be using about 30 mt .
Call Sign: Lemmy
Re: coax for scanning ???
Post by ch25 »
It's good.
I use sat coax for my rx antennas too. Low loss, low cost.
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
Thanks Chris if its good enough for you it will do for me to, what coax plugs do you use cb type please,
Call Sign: Lemmy
Post by ch25 »
Plugs depend on your needs.
For my miniwhip I use F type one side and BNC on the other.
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
HI would it be possable to use what they call twin shotgun coax to run two antennas say one for pmr and another one for 2mt/70cmt fed into two scanners would this be k ???
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Post by MrWeetabix »
Its just two bits of coax stuck together. As long as separate sources to separate receivers then should be fine. đź‘Ť
26TM175. OP: Craig. QTH: Gateshead. Also 163TM175 when mobile in Wales 8)
