Discone, double or half!
Ant
Call Sign: 26TM718
Post by Ant »
Many years ago I had a double discone fitted at a reomote station. That building has since undergone some work and many antenna arrays were removed.
Now what I'm left with is this........
....assuming I can straighten out the antenna probes, will this work as a single discone? Or should I just forget it and get a new one?
Shack? Shack is a poorly built building in a third world country, which is on the brink of collapse. I'm not calling mine a shack...
Ranger RCI2950DX
Uniden UBC3500XLT
Baofeng UV5RC
Baofeng 888s
Ant
Call Sign: 26TM718
Re: Discone, double or half!
Post by Ant »
No discone users?
Ranger RCI2950DX
Uniden UBC3500XLT
Baofeng UV5RC
Baofeng 888s
Tigersaw
Call Sign: GW6RRL
Post by Tigersaw »
I can't tell from looking, but is it the type where the next stage would have had a ring of horizontal elements, then a selection of different size angled vertical elements?
If so, it looks liek you are left with just the lower ground plane part, and it wont do much at all.
Ant
Call Sign: 26TM718
Post by Ant »
It's a double discone, so that lower array pointing down, would have the same pointing up. Looks like when it was removed from the building, the upper section was removed, then went missing. I can't even remember where I bought it from, I'm best with a new one that's for sure.
Ranger RCI2950DX
Uniden UBC3500XLT
Baofeng UV5RC
Baofeng 888s
Alan Pilot
Call Sign: MW7TTA
Post by Alan Pilot »
I have just put this one up and it works brilliantly.(see link)...
Also have the royal discone with the whip on top but not as good.
Mainly listen to marine and air bands.
Ant
Call Sign: 26TM718
Post by Ant »
The link you supplied has the whip on top? Is this not the one you got?
Ranger RCI2950DX
Uniden UBC3500XLT
Baofeng UV5RC
Baofeng 888s
Ant
Call Sign: 26TM718
Post by Ant »
So, looking to replace this antenna soon. I 'think' this may have been a SCANMASTER DD1300.
So, should I go for another one of those then? Or something else?
Ranger RCI2950DX
Uniden UBC3500XLT
Baofeng UV5RC
Baofeng 888s
