Hi all. I am back in the world of scanning and have the Uniden 125 and I cannot be the only one to find the instruction book somewhat lacking.
What I would like to do is scan between 2 frequencies (i.e. 27.60125 and 26.90125), in other words set my own range and scan between them.
I can use the Quick search where I can input a starting frequency but I want to select the end frequency such that it just scans between the 2.
Thanks in antic.
Matt
Uniden UBC125 - Manual range setting
- Mikel
Re: Uniden UBC125 - Manual range setting
Hi
Welcome to the forum
You can change the search limits of the pre programmed banks 1-10.
Possibly consider changing the limits of bank number 1?
Page 51 – 52 of the manual
Programming Custom Search Ranges
You can define each search range used during a Custom Search.
1. Press Func then Pgm/E in Custom Search mode to view
the Search menu.
2. Turn SCROLL CONTROL to Program Limits and press
Pgm/E.
3. Turn SCROLL CONTROL to Search Bank 1-10 and press
Pgm/E. You will see the previously programmed lower
frequency. At Lower, press Pgm/E and use the keypad to
enter the lower limit frequency then press Pgm/E.
4. Scroll to Upper and press Pgm/E. You will see the
previously programmed upper frequency. Use the keypad
to enter the upper limit frequency then press Pgm/E.
5. Press . Clr to return to the Select Bank menu. Repeat for
each custom search bank you want to reprogram then
press Srch/Svc to start searching
Also, I see that there is a video on youtube - 'Uniden UBC125XLT - Programming Custom Search Ranges'
https://www.youtube.com/watch?v=PqHG3VJJitE
Uniden scanners can be a bit 'challenging' to get your head around at first, but it is just a matter of getting familiar with the way things work
the Search menu.
Pgm/E.
- scan125
- Call Sign: 26TM8080
You may want to try my free/charityware and fully supported Scan125 Control Program.
https://nick-bailey.co.uk/scan125
Nick - Author Of: Scan125 - Scan75 - DriveR8 - http://www.nick-bailey.co.uk
