retevis RT3S
ngj35uk
retevis RT3S
Post by ngj35uk » 18 Nov 2019, 18:56
hi all i have bought the retevis RT3S a few weeks ago but i am having 2 problems i cant get it to scan on dmr also when i find a dmr frequency i can hear it but can see the signal i have private call match turned off also group call match turned off and still cant hear them talk. Any help would be greatful
thelad
Re: retevis RT3S
Post by thelad » 19 Nov 2019, 05:39
Not scanning will be a programming issue. If you have the correct CC, Sl and Tg then it could be data being sent or a RAS system so you wont hear any audio but will show the RX LED.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
ngj35uk
Re: retevis RT3S
Post by ngj35uk » 19 Nov 2019, 10:09
i have right cc and tg etc as i am getting all the right info from my sdr but i think it must be a setting thats wrong in software
thelad
Re: retevis RT3S
Post by thelad » 19 Nov 2019, 12:13
Are you getting audio from the SDR at the same time as not getting it from the radio? Does it say RAS on DSD? Sounds like it is.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
ngj35uk
Re: retevis RT3S
Post by ngj35uk » 19 Nov 2019, 13:23
i am getting audio from sdr and showing dmr+ tg9 slot 2 etc then i can see signal on radio but its like its not decoding it
thelad
Re: retevis RT3S
Post by thelad » 19 Nov 2019, 16:41
Have you got the Rx and Tx set correct?
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
ngj35uk
Re: retevis RT3S
Post by ngj35uk » 19 Nov 2019, 20:11
tx rx are both right i will get there in end will be something simple in end thanks for the help
thelad
Re: retevis RT3S
Post by thelad » 19 Nov 2019, 20:57
ngj35uk wrote:
19 Nov 2019, 20:11
If all is correct then its a RAS system. You wont get any audio.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
