RAS on a CAP+ System
Goffy
Post by Goffy » 20 Oct 2019, 04:17
I noticed my local hospital uses a CAP+ system spread across 4 frequencies. No idea if RAS or not. If they have RAS enabled will I hear a scrambled signal or just nothing at all? I've not even seen the LED light up to show any signal at all. I'm using a retevis RT3S dmr handie not a scanner but I've put the four freqs in the same scan list and not heard a peep. The radio works well with other DMR transmissions local to me.
thelad
Re: RAS on a CAP+ System
Post by thelad » 20 Oct 2019, 14:15
If its a Restricted Access System then all you will get on a Transceiver is the RX led with no audio. If its Encrypted then you will get garbled audio.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
