245Mhz Transmitions What is it?
mm3vee
Call Sign: mm3vee
Post by mm3vee » 28 Aug 2019, 14:46
Hi all i am getting What sounds like Skip On 245Mhz its all day long could it be satellite transmissions? if so anyone k how i could improve reception.I
am using RSD-DUO with diamond v 2000 antenna
Here is youtube i recorded
https://www.youtube.com/watch?v=QaLwT0BVUJw
Metradio
Call Sign: G7HID
Re: 245Mhz Transmitions What is it?
Post by Metradio » 28 Aug 2019, 15:35
South American illegal radio users - mostly lorry drivers on an open US DOD satellite.. has been going on for a while now..
Mike
Post by ch25 » 28 Aug 2019, 15:56
Satcom pirates.
To improve signal you need proper antenna: https://www.thingiverse.com/thing:388651
http://www.blackcatsystems.com/radio/sa ... tenna.html
grafter
Post by grafter » 28 Aug 2019, 16:27
Proper is good but it's overkill to listen to Satcom. Much easier to knock up a quick NBS yagi, it'll be 3dB down on circular which is nothing to worry about.
mm3vee
Call Sign: mm3vee
Post by mm3vee » 28 Aug 2019, 16:33
thanks, guys...
Any antennas i can buy cheap instead of building a kit?
Metradio
Call Sign: G7HID
Post by Metradio » 28 Aug 2019, 18:36
Then you will have to learn Spanish ...
Mike
Andy
Post by Andy » 30 Aug 2019, 10:40
I use a DAB folded dipole from B&Q. It seems to work best horizontally, but there's not a lot in it. The transmissions can pop up almost randomly between about 245 and 256 MHz, so it's worth tuning about. There are some satellite transponder 'stripes' around 244.2 and 249.2 as well, which you should see if you are using an SDR.
'SOMEONE GET ME A SAW!'
Andy.
Andy
Post by Andy » 30 Aug 2019, 10:47
Stripes today on 244 MHz.
Andy.
radiosification
Post by radiosification » 31 Aug 2019, 11:33
Metradio wrote:
28 Aug 2019, 18:36
Mike
I think most of the pirates on satcom speak Portuguese actually. At least in the recordings I've seen
Metradio
Call Sign: G7HID
Post by Metradio » 31 Aug 2019, 16:17
Portuguese - Spanish with a Welsh accent :D
Mike
