BAOFENG UV-5R how to enter and save the pmr 446 channels PLEASE
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
Can anyone please help ? i am tring to enter the pmr 446 channels into my baofeng uv-5r radio , i am useing the 6.25 steps but cannot get it to save lets say 446.0062 it saves 446.000 how do i get it to save 446.0062 ??? PLEASE
Ur5by9
Re: BAOFENG UV-5R how to enter and save the pmr 446 channels PLEASE
Post by Ur5by9 »
i'm sure i used a program called chirp and just copied the PMR channels across , took merely 5 minutes, you will need the cable to program the radio from the computer, mines came with the radio .
1 446.003125 MHz 6.25 kHz Allowed for digital FDMA operation after January 2018
2 446.009375 MHz 6.25 kHz
3 446.015625 MHz 6.25 kHz
4 446.021875 MHz 6.25 kHz
5 446.028125 MHz 6.25 kHz
6 446.034375 MHz 6.25 kHz
7 446.040625 MHz 6.25 kHz
8 446.046875 MHz 6.25 kHz
9 446.053125 MHz 6.25 kHz
10 446.059375 MHz 6.25 kHz
11 446.065625 MHz 6.25 kHz
12 446.071875 MHz 6.25 kHz
13 446.078125 MHz 6.25 kHz
14 446.084375 MHz 6.25 kHz
15 446.090625 MHz 6.25 kHz
16 446.096875 MHz 6.25 kHz
17 446.103125 MHz 6.25 kHz
18 446.109375 MHz 6.25 kHz
19 446.115625 MHz 6.25 kHz
20 446.121875 MHz 6.25 kHz
21 446.128125 MHz 6.25 kHz
22 446.134375 MHz 6.25 kHz
23 446.140625 MHz 6.25 kHz
24 446.146875 MHz 6.25 kHz
25 446.153125 MHz 6.25 kHz
26 446.159375 MHz 6.25 kHz
27 446.165625 MHz 6.25 kHz
28 446.171875 MHz 6.25 kHz
29 446.178125 MHz 6.25 kHz
30 446.184375 MHz 6.25 kHz
31 446.190625 MHz 6.25 kHz
32 446.196875 MHz 6.25 kHz
AshtonMobileScanner
Call Sign: 26TM931
Post by AshtonMobileScanner »
There the digital pmr channels on DPMR446
Motorola UHF DP3600 x2,
Golden One 1907,
Baofeng UV5RA+,
Diamond RH771 Antenna,
UHF Stubby Antenna,
Diamond X-30 Antenna,
MASS SPS 250 MK2.
(Monitor All Channels)
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
Would there be any sence in adding thouse digital channels to my baofeng uv-5r radio ? as i do not think it can handle digital ???
radiosification
Post by radiosification »
No, in fact you won't be able to add the 32 channels with 3.125 kHz steps (I think the UV-5R supports only 6.25 kHz steps). Look up a list of the 16 channels instead and use them. They are used with 12.5 kHz spacing which is what you want for receiving analogue stuff.
AshtonMobileScanner
Call Sign: 26TM931
The PMR/DMR 446 channel list is:
1 446.00625 MHz
2 446.01875 MHz
3 446.03125 MHz
4 446.04375 MHz
5 446.05625 MHz
6 446.06875 MHz
7 446.08125 MHz
8 446.09375 MHz
9 446.10625 MHz
10 446.11875 MHz
11 446.13125 MHz
12 446.14375 MHz
13 446.15625 MHz
14 446.16875 MHz
15 446.18125 MHz
16 446.19375 MHz
Legal for both analogue and DMR 0.5 Watt 😉
For DMR I use them all on CC1 G1 S1, I have seen CC1 G99 S1 mentioned but not seen any default group for DMR. So pretty much use any talkgroup you want.
For more info see https://en.wikipedia.org/wiki/PMR446
Golden One 1907,
Baofeng UV5RA+,
UHF Stubby Antenna,
MASS SPS 250 MK2.
