Hi I have some Sepura SRP2000 radios, I have had them programmed them up with all the same channels on, but there seams to be a problem with a couple of them and they don't want to seam to talk to each other, I was wondering if there was a setting we have missed.
thank you in advance.
Sepura SRP2000
Re: Sepura SRP2000
The 2 that are giving you a problem do they talk to each other but not the others? Did they work previously but all of a sudden stopped?
Did you programme them yourself?
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
- Call Sign: M6BYS
Re: Sepura SRP2000
Hi, I believe they are radios that are being added on, I'm asking for a friend.
Re: Sepura SRP2000
The problem is you can name the channel or talkgroup the same but have different settings.
Possibly not the same settings so would need reprogramming to the same as the rest.
But unless the radios are in front of me I have no way to confirm that is the case
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Re: Sepura SRP2000
I had a similar issue a while back programming an SRP2000 to work with some MTP850 sets . I put it on a back burner and that was a few years back as DMR took over in a big way.
I may have to fish them out and breakout the laptop with RM. Its been a while working with this CPS, any pointers?
MTIA
Mike
MTIA
Mike
