Sepura SRP2000
Ado99
Call Sign: M6BYS
Sepura SRP2000
Post by Ado99 »
Hi I have some Sepura SRP2000 radios, I have had them programmed them up with all the same channels on, but there seams to be a problem with a couple of them and they don't want to seam to talk to each other, I was wondering if there was a setting we have missed.
thank you in advance.
scottyboy
Re: Sepura SRP2000
Post by scottyboy »
The 2 that are giving you a problem do they talk to each other but not the others? Did they work previously but all of a sudden stopped?
Did you programme them yourself?
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Ado99
Call Sign: M6BYS
Re: Sepura SRP2000
Post by Ado99 »
Hi, I believe they are radios that are being added on, I'm asking for a friend.
scottyboy
Re: Sepura SRP2000
Post by scottyboy »
The problem is you can name the channel or talkgroup the same but have different settings.
Possibly not the same settings so would need reprogramming to the same as the rest.
But unless the radios are in front of me I have no way to confirm that is the case
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
mjm320340
Re: Sepura SRP2000
Post by mjm320340 »
I had a similar issue a while back programming an SRP2000 to work with some MTP850 sets {bnghd} . I put it on a back burner and that was a few years back as DMR took over in a big way.
I may have to fish them out and breakout the laptop with RM. Its been a while working with this CPS, any pointers?
MTIA
Mike
