Converting GP680 to GP380
Nelixuk2003
Post by Nelixuk2003 »
As the title suggests, I'm looking to downgrade my newly aquired GP680's to GP380's, mainly as I don't need the trunking capabilitys and would prefer more than the 16 channels that are available on the 680's when using them in conventional mode.
First off, I have a programming cable on the way, it's not a RIB but I have programmed the GP series of radio's in the past and had great success with the RS232 serial cable. What I hope to do is update them to the same, most recent firmware (I know I need a RIB for this bit).
Has anyone ever done this before? I will probably need a 380 codeplug and the correct version of the CPS software, I'll have to check which version I already have from when I previously owned some of these. The only information I have relating to the radios at the moment is as follows:
I have 6 of these
Tanapa - 5 x Radios are PMUE1437D. 1 X Radio is PMUE1437C
Model - 5 x Radios are MDH25RDH9CK6AE. 1 X Radio is PMUE1437CAE
Version - R02.06.04 (x1). R02.09.01 (x3), R02.07.05 (x2)
Any advice or pointers would be greatly appreciated.
Kind Regards
Nelixuk2003
radiogaga
Call Sign: 26TM399
Re: Converting GP680 to GP380
Post by radiogaga »
You will need the 232 cable and genuine Motorola Flash Adapter.. (Can be hard to find)
I think from memory it can only be done at a certain firmware state, what that is I don't remember - sorry. I'll see if I can dig out some old notes.
You may be wasting time and money on this one.....
30TM399 Northern Costa Blanca
Nelixuk2003
I know it can be done as I have read of others being successful in doing this. I just need to know what I need In Place before I start tinkering.
If you could did out those notes you mentioned that would be greatly appreciated.
Regards
Nelixuk2003
radiogaga
Call Sign: 26TM399
Post by radiogaga »
I will but as I say you will definitely need a genuine flash adapter and RS232 cable, do you have those?
Fake RIBs won’t do it.
Nelixuk2003
I don’t own one but one of the guys at the local radio club has one, I checked and it is a genuine one.
