Motorola Codeplug wanted
AxelBelucci
Post by AxelBelucci »
Hello,
I need a blank codeplug for Motorola DP4400 UHF, can any one me help to find this codeplug?
Thank you
radiosification
Re: Motorola Codeplug wanted
Post by radiosification »
If you have the MotoTRBO CPS there are sample codeplugs in one of the program folders.
AxelBelucci
Hello,
I have two different CPS, but in this two I haven't an DP4400 codeplug.
Can't you me send an codeplug?
Thank you
Radiotronics
Post by Radiotronics »
By far the best way to modify a Motorola DP(anything) radio is to read in the radio. If that's not possible, and the only viable reason is that it's password protected, the other way is to use a default code plug to overwrite the existing codeplug inside the radio.
Presuming you have MOTOTRBO software, the sample (default) code plugs are in this folder:
Code: Select all
C:\Program Files (x86)\Motorola\MOTOTRBO CPS\samples
AxelBelucci wrote:
14 May 2018, 15:58
I have two different CPS, but in this two I haven't a DP4400 codeplug.
The only way this is possible is that you have the non-EMEA version of MOTOTRBO. In which case, even with a DP4400 code plug, you would still not be able to modify a DP4400.
Here's an explanation...
MOTOTRBO radios and software are region specific. If you look on the back of any Motorola Solutions radio, you will find a number that looks something like this "MDH56RDC9JA1AN". This model number is for a EMEA UHF DP4400 (non-E) version. The first two letters (MD) represent EMEA region, AA would be USA/North America. There are more regions including South America, Australia/New Zealand, China etc.
In EMEA and USA, there is a distinct difference between the radios - and they're called different things. For example, there is no DP4400 in the USA but an identical radio called XPR7350. So this makes a good distinction. But nevertheless, you need MOTOTRBO USA / North America to program an XPR7350 - and it will not program a EMEA model.
In Australia / New Zealand region, the DP4400 whilst appears to be the same radio as the EMEA DP4400 is, in fact, a different region radio. You'll need MOTOTRBO version for Australia to program this radio.
Yes, very confusing...
Two Way Radio Specialist
AxelBelucci
Hello,
Thank you for the useful information.
Can you tell me the difference between the model H56RDC9JA1AN and the H56JDC9JA1AN, since normally the "JDC" model is common?
Thank you
Radiotronics
Sure. Very simply...
[MD]H56RDC9JA1AN = DP4400 UHF
[MD]H56JDC9JA1AN = DP4400 VHF
AMX97
Post by AMX97 »
I recently got the Motorola MOTOTRBO CPS 2.0 UK & Europe Programming Software (GMVN6241A)
but there are next to no sample there for me.
there is only
DM4601e
DP1400
SLR8000
XiRM8660i
XiRP3688
DEP450
DGM8500e
XPR5550e
CP200d
how can i get sample code plugs for the DP4400... i don't currently have the radio at the moment due to current climate shipping is taking longer than expected.
Thanks.
TYT - MD380
TYT - MD390
Aliunce HD-1
Motorola DP4400e
Motorola DP3601
Baofeng UV-82
Baofeng UV-5R
uniden ubc125xlt
Moonraker M10
thelad
Post by thelad »
AMX97 wrote:
09 Jun 2020, 10:51
there is only
DM4601e
DP1400
SLR8000
XiRM8660i
XiRP3688
DEP450
DGM8500e
XPR5550e
CP200d
Thanks.
Pm me your email addy.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
AMX97
Post by AMX97 »
thelad wrote:
09 Jun 2020, 16:56
AMX97 wrote:
09 Jun 2020, 10:51
there is only
DM4601e
DP1400
SLR8000
XiRM8660i
XiRP3688
DEP450
DGM8500e
XPR5550e
CP200d
Thanks.
I've pmd you.
TYT - MD380
TYT - MD390
Aliunce HD-1
Motorola DP4400e
Motorola DP3601
Baofeng UV-82
Baofeng UV-5R
uniden ubc125xlt
Moonraker M10
AMX97
Post by AMX97 »
My dp4400e has arrived but when I connect it to my pc it asks for a password before i do anything the seller says they don't know the password so I can program it... is there any ways in witch I can "factory reset" it so to say or a way to get round it in the CPS.
Thanks.
TYT - MD380
TYT - MD390
Aliunce HD-1
Motorola DP4400e
Motorola DP3601
Baofeng UV-82
Baofeng UV-5R
uniden ubc125xlt
Moonraker M10
2E0UCW
Call Sign: 2E0UCW
Post by 2E0UCW »
If I remember correctly (it's been a few years since someone approached me with the same issue), you would need to clone a blank code plug into the radio. You may need to get a newer version of the CPS as there is a DM4401e sample code plug which may wite into your radio.
Motorola DM4600 ; Anytone 578 ; Anytone 868 ; Anytone 878 Plus
Whistler TRX-1 ; DV Mega ; Duplex Hotspot ; Zumspot USB
www.dmrguide.uk ; www.dmr-uk.net
AMX97
Post by AMX97 »
As far as im aware I have the latest one from radiotronics.
The only issue is that I only have a UHF sample code plug when the radio i have is on VHF... but from other posts I've seen some have issues with that.
TYT - MD380
TYT - MD390
Aliunce HD-1
Motorola DP4400e
Motorola DP3601
Baofeng UV-82
Baofeng UV-5R
uniden ubc125xlt
Moonraker M10
AMX97
Post by AMX97 »
Has anyone got a copy of a VHF codeplug they could send me for the DP4400E without a password.
TYT - MD380
TYT - MD390
Aliunce HD-1
Motorola DP4400e
Motorola DP3601
Baofeng UV-82
Baofeng UV-5R
uniden ubc125xlt
Moonraker M10
