Keeping a Motorola T5622 dry on a motorbike
- Guzzy
- Call Sign: 26TM002
RE: Keeping a Motorola T5622 dry on a motorbike
Put it inside the pannier?
- Guzzy
RE: Re: RE: Keeping a Motorola T5622 dry on a motorbike
Are they the posh aluminium jobbies?
That would effect the signal a tad.
If they are the plastic variety, I don't see a problem. I had a CB and then a PMR446 set-up in a plastic top box (even a pannier on occasion) that worked perfectly fine for 'convoy' use. I went so far as to drill holes and fit rubber gaskets to the top box for watertight cable routing.
