DIY DAB RADIO ANTENNA HELP PLEASE
- WARLOCK
- Call Sign: 26TM134
Wanting to make myself a dipole to improve the reception on my dab radio , Can anyone please help What lenth will i need to cut the wire for this , trouble is i do not know what frequency that is used for dab radio ?
Re: DIY DAB RADIO ANTENNA HELP PLEASE
Google know DAB frequency in UK for sure.
Does your radio have external antenna socket?
- WARLOCK
NO Chris it has not just a short antenna fitted
So forget it, unless you will modify your radio with external antenna socket.
Now all you can do is to attach a piece of wire to existing antenna and hope for better reception.
- Mitch
- Call Sign: M1TCH
Try a quarter wave at 31cm, UK DAB is around the 220Mhz mark, same as US ham band on 1.25m. A tiger tale could help but height is might with any radio aerial. If you're really struggling for signal put a socket on the radio and use a suitable yagi beam aerial
UK DAB frequecies:
11B = 218.640Mhz
11C = 220.352Mhz
11D = 222.064Mhz
12A = 223.936Mhz
12B = 225.648Mhz
12C = 227.360Mhz
12D = 229.072Mhz
UK DAB frequecies:
11B = 218.640Mhz
11C = 220.352Mhz
11D = 222.064Mhz
12A = 223.936Mhz
12B = 225.648Mhz
12C = 227.360Mhz
12D = 229.072Mhz
The perfect face for radio.
- TangoMike
- Call Sign: TangoMike
mybe something like this ?
- Black_Pirate
- Call Sign: 26TM034
Large bulldog clip added on the telescopic antenna weirdly worked from me in a cellar type place ha ha give it a try with a retune..
26T.M.034
GOOD LUCK IN DX
26T.M.034
GOOD LUCK IN DX
- Werthers
Build a yagi beam for it. It would be interesting to see what distant stations you can pick up. A 13 element would do.
- MrWeetabix
- Admin
- Call Sign: 26TM175
I fitted a SO239 to a DAB clock radio, still have it in the shed. was amazing RX when on the colinear.
Here it is receiving some Norwegian DAB back in 2016
- Werthers
MrWeetabix wrote: ↑01 Apr 2021, 07:13 I fitted a SO239 to a DAB clock radio, still have it in the shed. was amazing RX when on the colinear.
What colinear were you using?
- MrWeetabix
- Admin
That was with a lift on btw! haha. But I did live a mile from the sea and it was an X510 vertical.....Werthers wrote: ↑01 Apr 2021, 17:16MrWeetabix wrote: ↑01 Apr 2021, 07:13 I fitted a SO239 to a DAB clock radio, still have it in the shed. was amazing RX when on the colinear.
- Werthers
I gathered that besides it be pretty amazing if there wasn't a lift on and you got that station. Being by the coast helps and the X510 antenna has a nice gain on it.MrWeetabix wrote: ↑01 Apr 2021, 18:59That was with a lift on btw! haha. But I did live a mile from the sea and it was an X510 vertical.....Werthers wrote: ↑01 Apr 2021, 17:16MrWeetabix wrote: ↑01 Apr 2021, 07:13 I fitted a SO239 to a DAB clock radio, still have it in the shed. was amazing RX when on the colinear.
- MrWeetabix
- Admin
I use a comet GP-9 now and have some height. May bring it in from the shed and give it a go, see what stations I can get from here!
The GP-9’s Gain : 144 / 8.5dBi 433 / 11.90 dBi
It certainly feels lighter than the x510, that was a really heavy antenna
