Input and output impedance of a push pull amplifier using MRF101AN, MRF101BN
kop
Call Sign: AF7XT
Post by kop »
During a cleaning spree I found some cores. 1.12 x .375 x .6875".
Exact dimensions I ordered.
I have no clue what material these are .
Pics are YUUUUUUGE. getting used to a real (powershot A590 IS) camera. there will be a learning curve but you won't have to suffer through the cell phone cam.
Then this happened
It starts with a .png traced to a .bmp and then saved as a .svg.
I had not seen any new construction here for a bit and as much as I visit I had not been contributing.
NOT WINDOWS COMPATIBLE
kop
Call Sign: AF7XT
Re: Input and output impedance of a push pull amplifier using MRF101AN, MRF101BN
Post by kop »
Work continues on the 600 watt version
https://www.nxp.com/docs/en/data-sheet/MRF300AN.pdf
for the 200watt version
I have the code in .nc , .ngc , . gcode , the original art in png, bmp, and svg.
You can ask :D
Yamanx
Call Sign: 26FB001
Post by Yamanx »
Over me
How?
By all means think yourself big, but never think others small.... R.F.Scott
FBDX
kop
Call Sign: AF7XT
Post by kop »
kop
Call Sign: AF7XT
Post by kop »
tomias
Post by tomias »
Hi,
Thank's for the detailed explanations, excellent work,
theEarwigger
Call Sign: M0RZF
Post by theEarwigger »
http://www.m0rzf.co.uk/PA/index.html
Scroll down the page...
