Server converted power supplys.
kr0ne
Re: Server converted power supplys.
Post by kr0ne »
Neutrik SpeakON connectors are quite nice for power supplies. Really solid, latching and good for 30A+ :thumbup:
sec1223
Post by sec1223 »
and how the hell do i connect them to that board?
i think il stick to the amp terminals iv posted when i find out the name of them
cant stand IGNORANT b******ds
cjay
Call Sign: cjay
Post by cjay »
Fixing screws, through the board, solder the head to one side of the board and bolt the block to the other.
sec1223
Post by sec1223 »
only trouble is cjay, iv only got about 2mm clearance under the board once the cover goes on.
i need to find the name of them bleedin connectors lol
prettypolly
Call Sign: 26FB185
Post by prettypolly »
spade connectors
kr0ne
Post by kr0ne »
sec1223 wrote:and how the hell do i connect them to that board?
LOL, well if you hadn't wasted all that time de-soldering those blade connectors you could have wedged some fat cables in them then soldered them in place! ;)
cjay
Call Sign: cjay
Post by cjay »
Like everyone else does when they convert these supplies :)
sec1223
Post by sec1223 »
the blades are very close together and surrounded by plastic so that idea is out of the window.
sec1223
Post by sec1223 »
thats a load of bolocks or it would of been mentioned well before now.
sureshot
Call Sign: 26TM413
Post by sureshot »
Where ever possible i like to take the voltages off the board to a more practical connect disconnect system. If it means direct wire solder i do that, then take the wires or cable to my posts or terminals. I think terminal directly to the pcb can become weak with connecting and unconnecting. You can normally always find a positon to site some output terminals. The only time i terminated from the pcb was on a blade interface server, the pads where gold and the pcb was high quality grp, so it made a sound base to mount 4 mm posts, which can handle plus 25 amps easily.
CB call. Shipwreck.
cjay
Call Sign: cjay
Post by cjay »
Now now, that's not very polite is it...
I suggest you go and have a search around the 'net for pictures of converted supplies, almost all the pics that show the connector style you had show soldered connections.
Next time, perhaps before you rush in you should do some research.
sec1223
Post by sec1223 »
sureshot wrote: The only time i terminated from the pcb was on a blade interface server, the pads where gold and the pcb was high quality grp, so it made a sound base to mount 4 mm posts, which can handle plus 25 amps easily.
thats what i intend doing but once its connected, it wont be getting disconnected very much at all and thats why i think the soldeed block terminal type connector will do.
sec1223
Post by sec1223 »
i did my reserch on here and got some very helpful advice and ideas off yourself and others.
and as for being polite, i have been, until i was mocked which in turn is also not very polite neither.
radiogaga
Call Sign: 26TM399
Post by radiogaga »
I've done two of these conversion now, one I used busbar: http://www.screwfix.com/p/mk-20-module- ... kpid=72378
The other I did the cheap way.
Both work and have had 50amps off the back of them no problems
The busbar method I had removed the connector like you did, didn't fancy drilling through the board, couldn't be sure it's not multilayered.
I don't have a picture of the busbar version since my mate has the PSU now. Both are intended to be mounted in an ABS box so pretty is not a consideration.
Hope that may help?
30TM399 Northern Costa Blanca
cjay
Call Sign: cjay
Post by cjay »
Oh well.
Will definitely think twice before offering anyone help again.
