Transformer Hum
Auldgeek
Transformer Hum
Post by Auldgeek »
Wasn't too sure where to post this, as it's not home brew. However, as there's plenty of discussion here about Power Supplies, I've taken a punt.
Anyway:- Hello! :wave:
I have an annoying issue with a Daiwa Power Supply. It's a PS-304 30A linear type supply. Supply is, in every other sense of the word, in good working order except some really annoying transformer hum. Supply provides a stable output and a good dose of Amps (I've drawn 20A from it for several minutes) but the hum can be very loud. I'd even go as far as saying that there's a change to its physical resonance when I place my hand on the enclosure and draw current.
It doesn't always do this but more often than not when supplying anything more than 2-3A.
Now, from my experience, transformer hum normally comes about either by stray RF current field effect when the transformer core is magnetised or small variations and uneven vibration from the layers making up the core (magnetostriction)
On this supply, everything is stock, no components have been replaced and from what I can see and measure, everything is as it should be. I've went as far as tightening up the transformer plates and ensured everything else is securely tightened. Ive also sat the supply on sound deadening material.
One other thought occurred to me. Is it possible the transformer itself has undergone a degree of delamination? I'm mentioning this, as the hum increases as more current is being drawn and it could simply be the adhesive layer between the laminations is breaking down.
Has anyone had any experience of this effect and been able to dampen it sufficiently? I've read some stories of folk pouring glue in to transformers but not of the size in this supply.
Drew
Auldgeek - Drew
Amateur Callsign GM0BRJ
TM Callsign 108TM144
Thank you NHS :clap:
Andy
Re: Transformer Hum
Post by Andy »
It may not be the transformer itself, just the steel parts of the case which are vibrating in the magnetic field. Slackening the case screws and doing them up again may make it go away. If it is the transformer, often a sharp whack with a big hammer will re-arrange the windings and cores enough to make it think twice.
'SOMEONE GET ME A SAW!'
Andy.
Auldgeek
Re: Transformer Hum
Post by Auldgeek »
Thanks for the input and suggestions.
I think at one point, it was rattling with the case removed but I'll need to double check.
Cheers.
Auldgeek - Drew
mr_m3
Re: Transformer Hum
Post by mr_m3 »
I have the exact same issue on my watson W-30AM 35A supply, some advice i was given was to get a big set of locking jaw pliers and squeeze the transformer to almost crimp the wire slightly and re tape.
let me know how you get on i may do something to mine soon
26TM069
M3UBO-----> 2E0FML---->2E0PUC
Mikel
Re: Transformer Hum
Post by Mikel »
mr_m3 wrote:
29 Nov 2019, 18:49
I have the Watson W-25AM, I have had it for many years and the transformer is pretty good on the noise front, but the fan is a different matter!
Sounds like a helicopter coming in to land!
I eventually modified mine by setting the voltage to 13.8 with the pot on the board and use the voltage adjustment knob on the front panel to control the fan speed - much better for my sensitive ears.
mr_m3
Re: Transformer Hum
Post by mr_m3 »
Mikel wrote:
02 Dec 2019, 09:37
mr_m3 wrote:
29 Nov 2019, 18:49
Funny you should mention that, the temperature controlled fan circuit has died on mine and with a 15A+ load for a long time it overheats and shuts off, eventually coming back on once it cool down. I’ve bought a small PWM fan speed controller to fit into mine to have a variable fan and fix the fan in one go
26TM069
Auldgeek
Re: Transformer Hum
Post by Auldgeek »
Not the supply I have the transformer hum but a more recent My-Del clone had a fan like a jet Turbine.
I replaced the fan with an Artic Silent cooler. Now, the supply is effectively silent and because the fan has better airflow, the supply stays cool.
Auldgeek - Drew
wa10
Re: Transformer Hum
Post by wa10 »
How bad of a hum are we talking about here ?, if its VERY loud not just the normal bit more hum under load, change the bridge rectifier,
bridge rectifiers like the daiwa uses can blow in a mode that the psu still works ok until you start drawing current where the transformer starts huming MUCH louder than it should & vibrates the case.
W8JI
Auldgeek
Re: Transformer Hum
Post by Auldgeek »
wa10 wrote:
07 Jan 2020, 22:40
Thanks for the information. Yes, it's very loud and increases when loaded. Definitely not a normal hum!
I have read about issues with the bridge rectifiers in these supplies but they normally blow the fuse when they fail.
There seems to be a few variants of this supply and some utilise two 35A rectifiers and others use a single rectifier.
I've not been able to progress this any further but when time allows, I'll have a look at the rectifier.
Auldgeek - Drew
wa10
Re: Transformer Hum
Post by wa10 »
I don't know of any other fault that causes a seemingly working linear psu to hum much louder than normal when you draw current,
i replace the 35a with a 50a bridge & add an inrush thermistor to protect the rectifier at switch on,
good luck
W8JI
