G0xbu online sdr ?
gmham
Call Sign: 108TM154
G0xbu online sdr ?
Post by gmham »
Guys came across this version of the G0xbu online web sdr
http://81.174.147.103:8901/
Great receiver but just can’t seem to move the freq in anyway apart from manual entering the freq. normally you move the slider of the waterfall along but this doesn’t work for me either, tried the up/ down freq buttons but still nothing. Using the receiver on an iPad, just wonder if it’s possibly designed for chrome or android etc ?
Anyone advise ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Alan Pilot
Re: G0xbu online sdr ?
Post by Alan Pilot »
Just tried it and i just used the arrow's and the frequency went up and down. < and >.........
gmham
Call Sign: 108TM154
Post by gmham »
Okay thanks Alan strange take it you are using an iPad as well ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Mikel
Post by Mikel »
gmham wrote: 28 Oct 2020, 12:02 Okay thanks Alan strange take it you are using an iPad as well ?
I have the same problem with my ipad as well. Have you tried the mobile site?
http://81.174.147.103:8901/m.html
Just figured out how to change bands, touch the display and type in the frequency - not had enough coffee yet obviously :?
gmham
Call Sign: 108TM154
Post by gmham »
Mikel wrote: 30 Oct 2020, 09:49
Okay thanks will give your link a try. Mentioned it already that I can change freq by entering it manually but as I say just can’t seem to move up or down freqs on the original link . guessing the software is intended for android etc as opposed to iOS.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
gmham
Call Sign: 108TM154
Post by gmham »
gmham wrote: 30 Oct 2020, 09:55
* Tried your link but although as you say touching the freq brings down a list of freq / bands to choose from and dial moves pressing the bands seems to make no difference, is yours changing bands ok ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Mikel
Post by Mikel »
gmham wrote: 30 Oct 2020, 10:00
Yes, it is a bit strange, I cant use the buttons to change freq either.
To change band you have to touch the display that as you say brings down a list and then type in the frequency on the band that you want without adding the decimal point. You can then tune up and down on that band either with the buttons or by dragging the waterfall.
Mikel
Post by Mikel »
Alan Pilot
Sorry for the late reply but no i am using chrome on my pc.
Mikel
Post by Mikel »
Alan Pilot wrote: 30 Oct 2020, 10:41
Yes it is working fine on my Linux PC on Firefox but not on my ipad but the that is why there is a mobile version I suppose. That seems to work OK on my ipad.
As far as web SDR goes my favourite are the kiwisdr receivers. There is one near me in Weston Super Mud that has multiple antennas and I use it as my main HF receiver, (I transmit from here and receive from there) because the noise level is so high around here and I cant hear a thing from 12m down to top band.
Only HF but still good:
http://kiwisdr.com/public/
Type weston in the search bar and it brings up all the different antenna options for different parts of the spectrum.
gmham
Call Sign: 108TM154
Post by gmham »
Perfect appreciate that will check it out.
John
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
