Which is Best
Which is Best
Hi Folks
Just getting into SW
And wondering if anybody could advise me on the Following
which is best
Yaesu FRG 7700
OR
Yaesu FRG 100
Thanks in Advance
Chas
which is best
Yaesu FRG 7700
OR
Yaesu FRG 100
Thanks in Advance
Chas
- dcwuk
Re: Which is Best
Have a look here for a review.
https://www.eham.net/reviews/view-product?id=476
https://www.eham.net/reviews/view-product?id=1808
just bear in mind your receiver is only as good has your aerial
- Call Sign: Lemmy
Re: Which is Best
And treat those reviews as entertainment only. All it's worth.
Re: Which is Best
If your after a base station go for the frg100. I have had it over a year and had some good stations to listen to. More and more people are going over to sdr though.
- scan125
- Call Sign: 26TM8080
Re: Which is Best
You may want to look at the Alinco DX-R8. This is a current model and not much more expensive than than the second hand Yaesu 100/7700 rigs
https://swling.com/blog/2011/09/alinco-dx-r8t-review/
https://www.nevadaradio.co.uk/amateur-r ... inco-dx-r8
If you want to also have some PC control, programming, recording, scheduled tuning, +++ then my DriveR8 Control Program (free) is available as well.
See:
https://www.nick-bailey.co.uk/DriveR8/index.html
https://www.nick-bailey.co.uk/DriveR8/M ... anual.html
See:
Re: Which is Best
picked up a frg 7700 cheers
- Chris64ex4
Re: Which is Best
Still got a Lowe HF150 for what limited shortwave listening I do.......
- scan125
Re: Which is Best
Then you need:Chris64ex4 wrote: ↑21 Jan 2020, 13:28 Still got a Lowe HF150 for what limited shortwave listening I do.......
https://www.nick-bailey.co.uk/hf150/index.html
- Chris64ex4
Re: Which is Best
Indeed but I need a new 3 way input level switch for the back of it first, existing one a bit knackered....scan125 wrote: ↑22 Jan 2020, 18:57Then you need:Chris64ex4 wrote: ↑21 Jan 2020, 13:28 Still got a Lowe HF150 for what limited shortwave listening I do.......
- scan125
Re: Which is Best
Do you mean serial communications IF-150 interface?Chris64ex4 wrote: ↑13 Feb 2020, 18:23 Indeed but I need a new 3 way input level switch for the back of it first, existing one a bit knackered....
If so then to find a replacement these days is going to be really difficult.
You can build my project though, which quite a few people have successfully done.
https://www.nick-bailey.co.uk/if150/index.html
- Chris64ex4
Re: Which is Best
No it's the 3 way switch on the back which selects the antenna input sensitivity. I'll have to download the circuit diagram and see if another 3 position switch will do.scan125 wrote: ↑14 Feb 2020, 12:36Do you mean serial communications IF-150 interface?Chris64ex4 wrote: ↑13 Feb 2020, 18:23 Indeed but I need a new 3 way input level switch for the back of it first, existing one a bit knackered....
