Scan125 Manual Com Port Selection error
Goffy
Post by Goffy » 23 Sep 2019, 00:27
DowloaDED AND INSTALLED LATEST VERSION OF sCAN125 AND THE DRIVERS. Sorry hit my caps lock there. It fails to recognise that my scanner is attached and suggests I manually select a COM port. The drop down COM port box gives me one choice COM1...select that and I get a recurring com port error box pop up. Its Windows 7 and I think I installed the drivers properly although I must admitt I'm a bit rsty on Windows as I only use Linux pc's these days.
scan125
Call Sign: 26TM8080
Re: Scan125 Manual Com Port Selection error
Post by scan125 » 25 Sep 2019, 17:23
Hi Goffy
Scan125 author here.
Can I ask you to contact me directly via Email (https://www.nick-bailey.co.uk/contact_us.html) on the Scan125 Email address.
Meanwhile did you?
1) download the Uniden Universal Serial driver from my wesbite? : https://www.nick-bailey.co.uk/scan125/download/
2) followed these instructions : https://www.nick-bailey.co.uk/scan125/M ... ual.html#7
I do follow (some) forums when I can but my priority attention is to contact via my official Email addresses.
Nick - Author Of: Scan125 - Scan75 - DriveR8 - http://www.nick-bailey.co.uk
Goffy
Post by Goffy » 08 Oct 2019, 03:59
Thanks for the reply. I will email you when I get the time. But first I will re-install the drivers following those instructions carefully to see if it solves the problem. I am using Windows 7.
Goffy
Post by Goffy » 12 Oct 2019, 00:45
Its working fine now. It turns out I hadn't correctly installed the drivers using the Device Manager in Windows 7. All sorted now and no need for me to bother you by email.
scan125
Call Sign: 26TM8080
Post by scan125 » 12 Oct 2019, 18:09
OK
I would like to take this opportunity to all users of Scan125 / DriveR8 / HF150 / future software to contact me directly via my website/Email addresses for each product.
I can not monitor all the various forums available on the net and those that I do are a secondary and non prime objective.
