Turned the radio on to find out the uk 40 fm is all messed up. If i reset the radio will i still keep the uk fm? bought the radio from Knights pre-programed so didn't get a cable.
Crt ss 9900 re-set question
Re: Crt ss 9900 re-set question
Hi When you do a reset you will lose the UK 40
You should be able to choose between CB or Ham but don't reset it try this =Master Virus wrote: ↑09 Nov 2019, 17:23 Turned the radio on to find out the uk 40 fm is all messed up. If i reset the radio will i still keep the uk fm? bought the radio from Knights pre-programed so didn't get a cable.
If your uk40 is all messed up = push the channel change/vco until one of the digits on the frequency readout flashes,this is the number you can change,when turning it.
You need the last big number on the right hand side,out of the 3 in between the decimal points to be a 1,then after the decimal point a 2 at the end of your read out,but some just have a 0 as that is close enough on fm.
The UK 40 starts at =
27.601.2
27.611.2
27.621.2
27.631.2
27.641.2
27.651.2
all the way to 27.991.2 which is UK Channel 40 in 10kc steps.
Push the channel changer/vco until you can change the required numbers needed to qet UK CH 19 which is 27.781.2,and have the 8 flashing but wait until it stops flashing,and if you go up a channel you will go to UK CH 20 or 27.791.2
Edit = should have been right not left handside.
27.555 Usb
27.555 Usb
Really appreciate the help because if this happens again i i'll know what to do.108EH002 wrote: ↑10 Nov 2019, 11:42You should be able to choose between CB or Ham but don't reset it try this =Master Virus wrote: ↑09 Nov 2019, 17:23 Turned the radio on to find out the uk 40 fm is all messed up. If i reset the radio will i still keep the uk fm? bought the radio from Knights pre-programed so didn't get a cable.
You need the last big number on the left hand side,out of the 3 in between the decimal points to be a 1,then after the decimal point a 2 at the end of your read out,but some just have a 0 as that is close enough on fm.
27.601.2
27.611.2
27.621.2
27.631.2
27.641.2
27.651.2
Really helpful advice
- ballo
- Call Sign: 19DD03
The 9900 can be messed up by switching between freqeuncy and channels. I had this with 2 9900's . You get this when you switch from from freqeuncy to channels and the last used freqeuncy will be written in the channel.I bought the 9900 with the cable and saved the "original" file before using the rig.
http://www.pa3hgt.nl
President Veep 40 ch am/fm , President Jackson Classic 6 bands ,HAM International Jumbo 3/Multimode 3/Viking 3,Midland 7001 MK3,President Jackson 2 chrome/JFK Chrome/Lincoln/HR2600/Franklin,Dirland DSS9000F,Petrusse Ecalibur 2002.
- Werthers
I've got a President Veep AM/FM as wellballo wrote: ↑16 Nov 2019, 21:36 The 9900 can be messed up by switching between freqeuncy and channels. I had this with 2 9900's . You get this when you switch from from freqeuncy to channels and the last used freqeuncy will be written in the channel.I bought the 9900 with the cable and saved the "original" file before using the rig.
Mine needs a service tho it worked ok when it was put away back in 2008 but now shows faults.
- ballo
- Call Sign: 19DD03
Hope that you will find a good technician !
It's all sorted but thank you everyone!
