President McKinley EU Incoming
cooper
Call Sign: 26TM111
Re: President McKinley EU Incoming
Post by cooper » 22 Nov 2019, 14:50
I purchased a Mckinley for mobile use in the van, unfortunately modulation on both FM and SSB are virtually non existent even with a power mic, i can see the FM Mod/Dev adjustment on the above picture but what is the adjustment for SSB modulation? the AM modulation adjuster?
delboyonline
Post by delboyonline » 05 Dec 2019, 18:32
cooper wrote:
22 Nov 2019, 14:50
Must be faulty if the modulation is that bad. I find the McKinley very good on all modes apart from FM where it's a little quiet.
Have you remembered to change the mic setting in the menu from Electret to Dynamic when using a power mic?
Auldgeek
Post by Auldgeek » 06 Dec 2019, 15:02
Definitely faulty in my mind if you've tried different mics.
Mine is fine, didn't have to adjust FM and even switching from dynamic to electret, there is still more than enough audio to drive SSB and AM to a decent level.
Auldgeek - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
cooper
Call Sign: 26TM111
Post by cooper » 10 Dec 2019, 14:32
delboyonline wrote:
05 Dec 2019, 18:32
cooper wrote:
22 Nov 2019, 14:50
I did try both Electric and Dynamic with no noticeable difference, so it went back to the suppliers and it was promptly return with the advice "that`s how they are supplied these days nothing wrong with it" ( not really impressed ) so i had to adjust both FM deviation and the SSB alc which has improved the modulation and SSB power output a bit.
delboyonline
Post by delboyonline » 11 Dec 2019, 15:37
cooper wrote:
10 Dec 2019, 14:32
delboyonline wrote:
05 Dec 2019, 18:32
cooper wrote:
22 Nov 2019, 14:50
It's just the modern specifications which manufacturers of legal CB radios must follow. Nothing actually wrong with them but they can sound quiet compared to older radios.
cooper
Call Sign: 26TM111
Post by cooper » 11 Dec 2019, 18:18
delboyonline wrote:
11 Dec 2019, 15:37
cooper wrote:
10 Dec 2019, 14:32
delboyonline wrote:
05 Dec 2019, 18:32
You are right, but it`s a pain in the arse when you have to make adjustments to brand new equipment just to heard {bnghd}
delboyonline
Post by delboyonline » 27 Jan 2020, 21:24
7 months on and still happy with my McKinley EU.
It's not really worth the money but it works well!
lambrettadave
Post by lambrettadave » 28 Jan 2020, 11:51
delboyonline wrote:
27 Jan 2020, 21:24
When compared to the Johnson II it's worth it
Phoenix
Post by Phoenix » 05 Feb 2020, 12:25
Did someone say the McKinley goes into meltdown when used with an Amp....I.E the transmitted audio becomes illegible.
26TM114
Auldgeek
Post by Auldgeek » 05 Feb 2020, 20:29
Phoenix wrote:
05 Feb 2020, 12:25
There was mention of this back in December on Simonthewizard's blog. Apparently the two he has show these symptoms.
I had meant to try mine hooked up to an amp but have never got round to it.
Anyway, it's about half way down the page
https://simonthewizard.com/2019/12/15/k ... ual-story/
Auldgeek - Drew
delboyonline
Post by delboyonline » 06 Feb 2020, 20:12
Tried mine on two different amps and all is well 😀
