It came like this: Not only were the two bits of perspex included, but they even had protective film on them, to stop them getting marked in transit! Final unwrapping:Mattylad wrote:Did it come in between the 2 bits of perspex or just as a PCB?
MR100 Antenna Analyzer
- Call Sign: 26TM553
Re: MR100 Antenna Analyzer
- Call Sign: RDX64
Aye up, you wrapped it up again for me - cheers.
It was only possible, after I reflowed the flux capacitorMattylad wrote:Aye up, you wrapped it up again for me - cheers.
- New User
- Call Sign: ok1rp
Hi,
There is $60 MR100 antenna analyzer toy - first test
http://youtu.be/82JGs1yC_cM
I got it from our local radioclub staff for testing.
It does not look so bad for these money.
I will be happy for comments and your experiences too.
73 - Petr, OK1RP
http://ok1rp.blogspot.com
73 - Petr, OK1RP
- New User
- Call Sign: ok1rp
Hi,
upon email's requests... yes the cheapest way is to buy the analyzer module itself w/o BT option. The metal housing, BT, battery pack, etc. is up to you. Latest v.13 firmware should be available.
The full spec can be found in the manual (see link) above.
I will try to make another video with functions and options available incl. calibration.
Basics:
The toy is powered from 12V/500mA w/auto power off
Max. measured impedance/reactance (C/L mode) is 2000 Ohms
Max. measured freq. is 60MHz
Steps 100Hz to 100kHz
Tests:
SWR, magnitude impedance, complex impedance, capacitance, inductance.
Derivate tests: ground loss, C, L, velicity factor, coax el. lenght, etc.
As it is using AD9851 DDS chip (Nyquist at 90MHz w/internal x6 multiplier clocks the DDS at 180MHz), the practical maximum output frequency from AD9851 is however about 70MHz. In my opinion as a third of the maximum DDS clock frequency for the AD9851 chip I prefer the maximum of 60MHz output frequency (lot spurs/aliases above). It is corresponding to the analyzer module spec.
I do not know more about it as I have not schematic yet.
73 - Petr, OK1RP
Basics:
Tests:
73 - Petr, OK1RP
- New User
- Call Sign: ok1rp
Hi all,
does anobody implemented this BT module and running it succesfully please?
I will be happy to know how to implement and where to get sw as I am thinking about buying it too.
Thanks,
Petr
Thanks,
Petr
Mattylad wrote:And how about fitting one of these in it to give it bluetooth?
http://www.ebay.co.uk/itm/SPP-C-Bluetoo ... 46373364c7
- Call Sign: RDX64
OK - just been prompted to spend my money instead of leaving it in the bank.
But instead of buying the unboxed version this is only a little more and comes complete with box etc.
http://www.ebay.co.uk/itm/261974482326? ... EBIDX%3AIT
Methinks I'll get that - all the same thing after all.
Thread revival.
Anybody know where to get the firmware from for this.
I have one but corrupt firmware.
