President Lincoln 2 - Version 3
13EL121
Call Sign: 13DA121
Re: President Lincoln 2 - Version 3
Post by 13EL121 »
Both of my L2 still work excellent. V3 by Stabo in the car for 10m and 11m. V2 at home.
gentlemanjohn
New User
New User
Post by gentlemanjohn »
So I was scanning the bands on my L2. Thought I need a roadmap to these channels. Never could find a roadmap, just a pyramid showing how the band's correlate to eachother. So if you can't find something make it yourself.
President lincoln II channel roadmap export mode.pdf
Now I was a little on the sleepy side so if you find an error lemme know.
Smudger
Call Sign: 26FI420
Post by Smudger »
simonthewizard wrote:
astradyne wrote:
Otter wrote:Do these Lincolns have the UK 27/81 channels 1-40 in them?
They do have the UK 1-40 channels, but not with UK 1-40 readout.
Go to a band like J which has frequencies in the 29-30mhz area
Change the channel one frequency to
2760125
and go though to channel 40
2799125
Radio will keep these channels and will not change till you reset it, so band J, I, H will stay at the 40 channels UK and in the right order
And why were the UK40 left out? SOLD AS AN AMATEUR RADIO NOT A CB RADIO which it is not type approved for.
So go buy one, you may enjoy it as it can be made 40 channels UK easily, no issues at all
Is there a you tube vid or something to show this, mine has been expanded but when i go to J and change to 27..... it jumps to a different band. I know this is old but any help greatly recieved
Smudger
Call Sign: 26FI420
Post by Smudger »
or alternatively is there in menu a way which i cant see to stop the VFO from being constant, ie it doesnt run the frequencies and returns to your original banded chanel 1
robber57
Post by robber57 »
The above mentioned method does not work with min either,could this be a version specific feature ?(V1-V2-V3)
I have read before about this feature that the vfo can remember how you have set it in a particular band but i have never found it.
What you can do in stead; if you go to 27.6012 and then put the vfo to the 10 khz position (the cursor) you can switch with the mike/chanel buttons/channel knob the uk channels, the channel indication is no good so you will have to keep a channel/freq list next to it but it works.
I just realise:
The function your looking for is menu function "keys setting" located at "UPdn" in the menu structure, you have it now set at "frequency" meaning the mike up/dwn and the panel up/dwn buttons will adjust frequency in steps according to where the cursor is located under the frequency counter,so if you have the frequency set to 27.125 and put the cursor on the 2 you can switch channels with both up/dwn buttons all the way across the band.
So if you go to 27.6012 and put the cursor on the 0 you can swith in the uk pattern all across the band.
If you put the UPdn option to "channel" (default) both up/dwn buttons will always bring the set back to the 10/5khz pattern of the cept channels and it will repeat all channels but stay within the current band.
In this mode using the uk channels means manualy adjusting the vfo for each and every channel.
So If you want to use the uk channels its more practical to keep the set in frequency mode , to make live easier to switch between uk's 10/12,5 grid and cept 10/5 grid you could make two memorys, one on 27.6012 FM(cursor on 10 khz) to go in "uk-mode" and one on a cept channel/mode to go back to cept mode.
Smudger
Call Sign: 26FI420
Post by Smudger »
robber57 wrote:The above mentioned method does not work with min either,could this be a version specific feature ?(V1-V2-V3)
I just realise:
Thanks for replying, yes i have the uk 40 ch19 set into memory one, but as we both can see no channel number, i was just hoping that there was some special mojo i couldnt find in the menu that allowed me to do as simon said in that previous post. No worries its working and to be fair a few channels either side of 19 is all about i need.
Smudger
Alaska99
New User
New User
Post by Alaska99 »
My Lincoln II V3 have ASC in AM and FM mode only... In LSB and USB the ASC don't work at all... Is it normal and there is a way to activate ASC in all mode?
Post by Admiral »
Why would you want squelch on SSB?
RadioPixie
Call Sign: 26TM552
Post by RadioPixie »
Alaska99 wrote:My Lincoln II V3 have ASC in AM and FM mode only... In LSB and USB the ASC don't work at all... Is it normal and there is a way to activate ASC in all mode?
Yes it is normal. If you really want to have squelch on SSB, go on manual squelch or turn the RF gain down a bit to reduce the background hiss levels. Most SSB operators don't use the squelch control.
To me personally, ASC is ideal for FM (not sure about AM, depends how noisy your location is) and no ASC for SSB. This is how many of the Anyclone (including the Lincoln 2) are designed these days.
Alaska99
New User
New User
Post by Alaska99 »
I like ASC when I scan in AM mode or to listen in AM because noise level change a lot. On SSB, ASC could be fine for scanning??
simonthewizard
Post by simonthewizard »
ASC as a design is AM only as designed by Albert Bertrana. It latterly in different generations worked on FM BUT AM mode it's better. SSB nope nothing at all, just AM/FM working but AM properly.
mr_m3
Post by mr_m3 »
How do the presient lincoln 2 compare to the likes of anytone 5555.
i quite fancy a modern freebander and the lincoln2 looks the mutts nutts, i did think about an midland 8001 but you hear all sorts of issues with them
26TM069
M3UBO-----> 2E0FML---->2E0PUC
robber57
Post by robber57 »
If i understood correctly the lincoln2 has the same board as the anytone 5555 and there are more who have the same board.
It is manufactured by a chinese oem builder, another member of the board will know the name, i have forgotten.
I have a 2v3, its not bad but its also not very good and on cw it is hopeless due to software errors,it doesnt latch correct if the first digit is a dit,
very (maybe even a bit to much) sensitive, you will have to get used to pull down the rf gain so noise doesnt get above s3-s5.
Audio response is bad (rolls of badly) but can be flattened with a simple mod, on of cb gurus on youtube made a video about it ( https://m.youtube.com/watch?v=FpJMks3UVsM )
I guess you can have roughly the same performance but cheaper if you dont buy the president version?
mr_m3
Post by mr_m3 »
I spoke to someone else who said they’re quite different. Look how the lincoln can’t be programmed as easy
26TM069
Adidas SoulBoy
Post by Adidas SoulBoy »
hi i am having a bit of trouble here trying to save 27.7812 into my memory on my lincoln 2 plus, It saves as 27.7850 is there a way to save 27,7812 . any help much appreciated thanks
