Yes this fantastic thread is still alive and well it would seem. I'd just like to echo others and say a big thank you for providing the build info and dimensions etc. Currently using a T2LT made of RG58 and speaker wire but when I get another roll (soon I hope) I'll certainly be giving this build a go & possibly making it a more permanent fixture than the current home base setup of 30' of random wood and a tree branch taped together & tied to the fence post! (I'm cheap though, so will probably wait till a good long roach pole comes through auction and try and get one for a fiver!)
Re: Homebrewing a Sirio Gainmaster using RG58 and 2.5mm wire.
Any chance to update dead links in OP?
- Call Sign: VK5LTD
I came across this antenna project after seeing a link on QRZ. 10m is lively during summer in Australia and a home brew 10m antenna for my beach house at Goolwa would be useful. Original pics/links are gone- did anyone save these? Will also check youtube. 73 Vk5LTD
- Stronty
PsiDoc's photos I think are these ones.
- Stronty
more
- Stronty
More
- Call Sign: 26TC62
- Location: Usually portable - Portsmouth or Isle of Wight
I've been thinking about knocking up one of these for a while - 99% of my operating is portable, and indeed it is "portable style" at home if I want to use anything more than an Ampro whip. In the field I have a homebrew "standard" 5/8 with a tapped coil and radials on a 10m fibreglass pole, and frankly stringing out wire radials is a faff. The aerial works fine but something radial-less and a bit more broadband is attractive - SWR gets up near to 2:1 at both ends of 11m and I do use both ends of it as well as the middle! I actually read about 60 pages of the thread on this as well on funkbasis.de earlier, with a lot of help from the Firefox Google Translate plugin. The thread there digressed into making a 3-el vertical Yagi using a T2LT driven element which has got me thinking!
I am going to pop into Nevada and pick up some Mini-RG8 and knock one up out of that to start with. Mini 8 is fractionally more lossy than RG213 but if the stub misbehaves, I have got a long run of Westflex kicking around in a storage unit somewhere. Mini 8 like Westflex is 0.8VF and 80pF/m so the stub tap-point and capacitor length will need to change from PsiDoc's schematic but the length of stub won't. Mini 8 is a bit better than RG58 and I refuse to use that stuff for anything.
- Call Sign: 26TC62
Well I got a good length of Mini 8 in anticipation of needing to get through a bit to produce a working antenna. The dimensions I've got at present are:
Top section of wire - 3.52m
Capacitor - 10cm (Mini 8 is quoted at 80pF/M)
Length to stub - 1.53m
Stub length - 71cm
Stub join to choke - 1.99m
So this gives the two "halves of the dipole" both at 3.52m. I started off with 3.45 halves as per the usual dimensions, but starting with the stub at 72cm (Mini 8, like Westflex is 0.8 velocity factor) the antenna was tuning too high up for me - minimum SWR was well above 28MHz. I trimmed the stub by about 5mm and it shifted down a bit, but not much, and then another 5mm and it brought the lowest SWR down to 27.9MHz
At this point I thought I'd try a bit more length rather than keep trimming the stub (I was worried of over-pruning the stub, and having to remake the antenna when I wanted to get out portable with it the next morning), I'd lengthen the elements. Having done that, to the above dimensions, I got the SWR curve in the image (taken from a Rigexpert AA35).
As you can see, I'm not getting the broad "W" curve but a very good match where the HF dip is and should be, and a slight "shoulder" where the LF dip should be - around 26MHz on the SWR plot. The 2:1 points are 24.9MHz and 29.05MHz or thereabouts. I haven't had a chance to do proper A/B testing against my homebrew 5/8 but looking at the S-meter on my local WebSDR, the level is about the same as the 5/8 is. I didn't put the 5/8 up when I was out as it was wet and windy, and I was hiding under my tarp chasing the DX! The weather is going to be better this weekend and I hope to get the chance.
Eventually I am going to make one of these up in RG213 with Westflex for the stub, but what I thought might be something that ended up needing considerable rework because I am using Mini 8 is already working well enough that there is not much hurry to do it.
Stub length - 71cm
- Call Sign: KB2HHU
I know the last post to this thread was a while ago however I tried reading through the many posts and really did not find the answers on constructing the antenna for outdoor use where you would mount it up on a mast (not a temporary setup). I have the coil of rg58 on PVC pipe and made the stub and capacitor out of RG-58. Testing with a NanoVNA shows pretty decent SWR from 26 to 30 MHz with the antenna wire hanging in the basement as best as possible. The question is though what is best material to use for the 24 feet or so of the wire (rg-58 with stub then 2.5mm wire) for making this vertical? I have tried using PVC pipe up to 1" and the 24 foot section to me seems too "floppy". Some posts mentioned a 10 meter fish pole that is telescoping which I have seen on ebay but I am not sure how well that would work.
- Call Sign: 26OD004
Thanks to everyone who made this thread and a special thanks to andi for the 213 dimensions. I made everything out of 213 so I copied all of your dimensions. Threw it up and it just worked. 1.5 swr on 25MHz and 1.5 on the bottom end of 28MHz. I wanted to move the resonant point up somewhat so I shortened the bottom coax element by winding half a turn onto the choke and the images below are what I have now. Not had chance to assess performance yet but bandwidth looks nice. The choke is probably 30 feet in the air, but I don't seem to be getting the double dip resonant points.....kamikazeandi wrote: ↑05 Dec 2015, 16:37 Hello,
I've modified the dimensions of my last 2 GM a bit. I built them for 2 HAM-friends. I built all coax-parts with RG-213. The upper radiator is made of flexible Cu-Wire with PVC-isolation. The dimensions for best SWR for me were at the end of testing (with "MY" RG-213):
And I've turned the choke 90°, so that the RG-213 "flows" more smoothly in the choke as you can see below (grey = GFK-Mast & black = GM):
Hope that helps a bit to build one yourself with RG-213.
kamikazeandi
So I've been messing around again this morn,
I wanted to see if reducing the choke down to 5 turns (4.25" diameter) would work and I got some strange results.
Reducing the choke size moved the resonant point up a full 1MHz into 10M, lengthening the bottom coax radiating section moved the resonant point lower down but very slowly and it was a faff so I wound the choke up to 9 turns (previously was using 11) and this is where I'm at now. I think there is more going on in that choke than just "choking"...
It'll stay as it is until next weekend at least.....
What it is most probably doing is as you unwind the choke it is becoming less or more effective so the antenna is seeing more or less of the feeder so you will be in effect lengthening or shortening the antenna26OD004 wrote: ↑13 Mar 2022, 16:00 So I've been messing around again this morn,
I have to ask... has anyone compared side by side a GM or an HBGM to a vector 4000???
I have recently built a standard Gainmaster 5/8ths using RG58 and RG2313 for the matching stub. It works really well on 10m and also just about on 12m if you lengthen the top radiator to around 3.6m.
A few days ago, I set about experimenting with the element lengths, series capacitor and matching stub to get the antenna to work better on 12m. The final lengths giving a VSWR of 1:1.2 on 24.9MHz and 1:1.2 on the bottom of 28MHz are shown below. The 1:1 match is at around 25.45MHz and the antenna never goes above 1:1.3 across the CB bands. The VSWR was measured close to the antenna (5m from the RF choke)
Series capacitor = 10pF made from 10cm of RG58
Upper radiator total length as per the design drawings on the internet = 3.61m
Antenna centre point (Electrical feed point) to stub attachment = 127cm
Stub length is 54cm of RG213 (Shorted at the end of course)
Total length of bottom radiator from antenna centre point to choke = 3.55m
You can fine tune the antenna by shortening the top radiator length by 5mm at a time and/or the bottom radiator by the same amount by threading more or less coax through the choke former.
