Anyone give me a link to a suitable fan to fit to the top of my little Kl203p ? Bought one fitted it and found it’s just too noisy ! Don’t really want to add any extras to slow it down etc so will just try pick up a quieter version.
Anyone ?
Quiet 12v fan for kl203 amp ?
- gmham
- Call Sign: 108TM154
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- Call Sign: AMC45
Re: Quiet 12v fan for kl203 amp ?
I use 120mm “uphere” fans on 503’s etc dead quiet
From Amazon
They might do a smaller one for 203
From Amazon
- gmham
Perfect will check them out. Appreciate that thanks.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Call Sign: 26DG01
Try a 12V PC fan on 5V. It'll run slower and quieter, and it might just be enough to keep everything cool. I use one on my main PSU, as it runs all the time it stops the PSU getting hot instead of having to cool it down.
Sent from my GP300 using DTMF
- gmham
Cheers buddy.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Transwarp
- Call Sign: Viper
Faster a fan spins the more noise they make. I find a decent quality 120mm fan spinning around 1150rpm is a good balance between cooling and noise. Noctua fans are very quiet but not cheap.
- Call Sign: 45
Agreed I too used smaller fans at reduced voltage but latter discovered a larger fan was far far quieter
- Transwarp
- Call Sign: Viper
Yes smaller fans have to spin faster to be effective hence more noise, bigger the fan less rotation needed. Other factors can add noise though such as blade design / geometry, bearing type, if blowing air through something or onto something. But overall its a either about cooling efficiency or noise.
