Cobra 25 Ltd ROC unidentified Mod..?
Redbandit
Call Sign: Redbandit07
Post by Redbandit »
Sammy or Claude, I also have a Cobra 25 Ltd. A gift from a brother in-law. He told me it has a mod, except he doesn't know what mod. Its a smaller pcb with wires running about. The thing is, there is a red wire that came off its solder point (where ever that is) and I have no idea where it may belong. When I turn it on, the needle shoots to the 30 range and doesn't change from there when I key the mike.
I am more interested in finding out what that board is, an echo or a beep? And if you have done a mod on any of your radios, where might that red wire go? ( see Photos). Thanks,
John
Black Spirit
Re: Cobra 25 Ltd ROC unidentified Mod..?
Post by Black Spirit »
Its a beep [Single tone], Red usually indicates positive supply and may have come off the positive connections on the back of the volume control.
14CS06
Post by 14CS06 »
Hello John
I do not know this modification
Nick has the correct answer
The PCB PC-417 is the same as
COBRA 21 GTL
COBRA 25 GTL
PRESIDENT AR-44
Claude
Redbandit
Post by Redbandit »
Just learning to move about this forum. Thank you Nick, for that shed of light. I was assuming that red was a power supply wire, but was sure bcuz the orange wire is thicker. That usually means it can handle some current. I had tried slightly touching it to that volume control source, and I would hear the relay click.
The Problem I see however, is that as soon as its turned on, the needle shoots to the complete right. (See Photo). That superstar mic you see there is new. I bought it a day ago, after I took the photos. Although I did try turning it on with the mic attached, it still shot to the right, I'm wondering if attaching the red wire, now that it has a mic, might bring the needle to its normal position?
Also, the mic is superstar DM507-4 for cobra radios. But I wonder if the pin numbers/color wires are correct. This mic has: 1-shield, 2- white, 3- red, 4- black.. Odd enough, I've looked on Google and find just the pin number and its function but not a color code chart.
Could you let me know if this is correct. Thank you,
John
Redbandit
Post by Redbandit »
Nick, my best guess is that you are correct that the little pcb is a roger beep mod add on. I took a chance and touched the red wire to the red of the volume wire and held it while I keyed the mic, when I let go, I heard a faint beep at the speaker. I imagine it would sound louder when its heard by others. I also saw the tx light turn red.
Now, as to where it was soldered to,. I took a look at both red and white wires on the volume pot, and the red solder connection is undisturbed. However the white wire connection is. And there's a drip of solder down below it on the meter, which kinda pushes my theory that this red wire was soldered poorly to the white one, and therefore fell off. Would it be safe to solder it back there?? (see photo).
Another odd thing is, that when I key the mic in testing the red wire, the needle moved down from the 30 to the 3. When I let go it went back to 30. I believe its supposed to be all the way to the tip of green, right? In either case, I only hear static snow, no chatter at all. Thanks again Nick.
John
Black Spirit
I couldnt tell you the colour code for the mic because i dont know what colour is connected to the PTT switch inside the mic, If you could post a photo of the PTT switch inside the mic then i could tell you which wire goes to which pin on the plug.
But even with the red wire off the beep board the radio should still have RX
Me personally i would remove the beep board and put the original wires back to the mic socket, The blue and orange will be the RX audio and TX wire [Which one is which i cant say from photos] But it would be very simple to figure which is which by touching the end of the wires to a ground source, One will give RX audio one will put the radio into TX then put the wires onto the mic socket the correct way.
