Superstar 6900N. Toyota Avensis and the brink of a nervous breakdown.
morgz84
Call Sign: 26UK81
Post by morgz84 » 11 Feb 2020, 23:30
Ever since I bought this motor i have had nothing but grief getting a radio working. Problem, after problem after problem. I have set up mobiles in two previous cars and it has been more or less plug and play, no issues what so ever other than the initial antenna tuning.
This car has been a nightmare. After numerous shenanigans finding an antenna setup I can get down to a usuable SWR, I am constantly having reports of poor muffled audio quality on SSB. It's one of those delightful problems which comes and goes to make it virtually impossible to diagnose. The poor audio quality coincides with hearing distorted feedback coming from the speaker, and a hideous squeal on AM. Generally, it seems to behave its self on FM. I have been through the manual and ensured that any talkback functions are off. This issue occurs with another identical radio and identical mike which I have. Both radios have previously worked brilliantly on the homebase set up where I used to live.
The setup is as follows:
Sirio ML145 PL mag mount
Modulator antenna connected via PL adaptor. Sirio ML145 antenna won't tune down to below 4 / 1, useless.
Superstar 6900N radio
Hi-Gear M75 power mike.
Coax running down side of windscreen, into bonnet and in through bulkhead. - This setup worked perfectly on two other cars I have owned.
Coax to mag mount has been replaced in it's entireity in recent days.
SWR is 1.5 or below.... until I plug in an extension between glove box and dash where I have it mounted, then it rises to around 2. Is the coax acting as the counter poise?! The reason for this setup is so that I can easily connect amp, SWR meter or external antenna if I wish. This is what I have always done with my car setups with no issue whatsoever.
So in trying to get rid of potential RF feedback (squeal on AM and screwed SSB audio), I have tried:
- Completely renewing coax from mag mount and all connectors.
- Different antenna. Tried 4ft Firestik which generally has better SWR than the Modulator.
- Different radio and mike.
- Running an ground from magmount ground terminal to chassis.
- Running an ground from radio chassis to car chassis.
- Tested radio on power pack pluged into extension lead.
After all this I can only conclude that either:
- Every piece of my radio equipment has broken at the same time.
- Toyota Avensis owners are not allowed CB radios in their cars.
- Paranormal activity is occurring
- MI6 / CIA / Mossad don't want me to have a hobby.
- All of the above
Could any of you lovely folk please give me any help to get into a more rational train of thought. At the moment, being rational, adult and logical has got me nowhere . I literally have no idea what to do, and frankly, I'm quite scared of what I will end up doing with the large lump hammer in my toolbox. I would quite like to do away with this mag mount and put a proper roof mount on the car but at the moment I just can't bring myself to pour any money into this sh1te show.
Re: Superstar 6900N. Toyota Avensis and the brink of a nervous breakdown.
Post by ch25 » 11 Feb 2020, 23:39
morgz84 wrote:
11 Feb 2020, 23:30
Yes. Coax, passengers etc. Forget about mag mount. Problem solved.
My own experience. I was able to stand next to my car with mic in hand, running 0.5kW into Santiago 1200 antenna and no squeal etc.
Just do it right :)
morgz84
Call Sign: 26UK81
Post by morgz84 » 12 Feb 2020, 16:43
Thanks. I think I'm going to do this.
Post by The Collector » 12 Feb 2020, 20:31
I drilled a nice hole in the roof of my '04 Renault Espace for my mount.
It is a heap of sh** though and being so is probably why it failed its MOT on Monday. Stupid ABS pump fault caused warning light to come on 2 days before the damn test was due. The scrap yard beckons lol.
morgz84
Call Sign: 26UK81
Post by morgz84 » 12 Feb 2020, 21:50
The Collector wrote:
12 Feb 2020, 20:31
I had a Passat which kept blowing ABS fuse and subsequently ABS light coming on. After much anguish, I deduced that there was a short on the main power feed to the pump and the clowns who had the car before me had "fixed" it with a 50 amp fuse instead of the 30 amp which should have been there! :shock: In the end, I back wired my own power feed with the correct 30 amp fuse and never had any more issues. Rather off topic I know, but thought you'd like that story.
Post by The Collector » 13 Feb 2020, 16:19
I'm no expert on mechanics personally, so all I can do is check the earth points (the 2 ABS fuses look ok as they have continuity), and check the connector block. A 2nd-hand unit will be needed otherwise. The damn thing's fitted in a really silly place according to a Google search, so the radiator grilles, engine tray, wheel arch inner covers and bumper's got to come off by the looks of it just to get to the thing!
Anyway...I digress sorry ;)
