Motorola GM-300 on 70cms
bigpimp347
Re: Motorola GM-300 on 70cms
Post by bigpimp347 »
Ant wrote: 01 May 2021, 10:32
bigpimp347 wrote: 29 Apr 2021, 22:10
I wish that was my page, i'd really let rip at the foundation dimwit shower of sh1t..
i run enough pages and groups and don't have time to mess with irrelevance.
Word for word, the things you say here are the same as on that page ;)
maybe people share the same opinion, but are too scared to show it ?
maybe certain words, phrases or comments are used quite often by similar like minded people ?
Ant
Call Sign: 26TM718
Post by Ant »
The man behind the facebook page doth protest too much, methinks.
Licence - British spelling
License - American spelling
bigpimp347
Ant wrote: 01 May 2021, 10:50 The man behind the facebook page doth protest too much, methinks.
no protest here,
prove it, that's all i can say..
hats off to the originator.
Ant
Call Sign: 26TM718
Post by Ant »
Yeah yeah ;)
Werthers
Post by Werthers »
Just an update on the GM300.
After more research on this radio, 40 channels may not be possible on the version I have.
My Motorola GM300 is 8 channels by default, only 16 channel Motorola GM300 radios can be made to do 40 channels so my 8 channel radio can only be made to do a maximum of 17 channels total.
I know to somebody reading this it may sound confusing....
8 channel Motorola GM300 = 17 channels total.
16 channel Motorola GM300 = 40 channels total.
To be fair the Motorola GM300 radios are a bit sh1te for amateur use anyway and get very hot even on low power so once I get mine sorted out I'll bung it on the 16 PMR446 channels and sell it, channel 17 will be scan.
Werthers
Post by Werthers »
I will have to teach myself how to use Hex Editor because there are no 16 channel GM300 software out there. I do remember there being a GP300/GM300 16 channel CPS I had it on a USB drive but it only worked for the GP300 handy talkies.
The GM300 software I had no longer works which is annoying because I can't find a working copy anywhere as yet. When or if I do find a working copy then I will need to edit the MDF file after I learn how to use Hex.
Once I've sorted this GM300 I'm never going to touch another GM300 ever again. Way to problematic.
Werthers
Post by Werthers »
bigpimp347 wrote: 01 May 2021, 10:44
Are you to scared to show yourself? What pages and groups do you "run" exactly?
LeakyFeeder
Post by LeakyFeeder »
What is it with some folk.... if you dont like what u see then block em... it ay rocket science.. 🙄
DX-Digger
Call Sign: TM205
Post by DX-Digger »
Werthers wrote: 07 Jun 2021, 08:03
You say it no longer works, have you tried running it in DosBox? you can usually get old dos based programs to work that way.
https://sourceforge.net/projects/dosbox ... taller.exe
Worth a try for the old program.
:thumbup:
Werthers
Post by Werthers »
DX-Digger wrote: 16 Jul 2021, 23:03
:thumbup:
It worked fine on my old computer until the motherboard failed. I tried it on other old computers using real DOS but the programming software did not want to work.
I got there in the end. I ended up finding another copy of the GM300 programming software and this one works fine in either Windows 98 or in pure DOS. I modified the MDF file for 40 channels but I could not get the UHF GM300 past 8 channels despite modifying the MDF file however I got my VHF GM300 to do 17 channels with the same software.
I did some research on the model numbers to check I had the correct transceiver versions and both radios have the correct model numbers for the 40 channel mod, I will have to seek expert advice on this. Work in progress... 17 channels on the VHF GM300 isn't to bad.
