I was asked recently can i connect my station to the mains earth.
My reply was try to keep Rf away from mains earth & put in a good RF ground using a non resonant thick braid or strap as short as possible.
Thinking about my advice it's best to ask for clarification as I'm not on a protective multiple earth system. I believe that Their is a danger with it.
Advice from a professional would be appreciated.
Ground loops
- Call Sign: 26TM2806
Ground loops
When you read up earthing your radio station you are warned about ground loops & are shown diagrams like this.
Re: Ground loops
But other books show this as recommended.
If you join the radio to the accessory with coax, Doesn't it form a ground loop if that accessory is an ATU or linear amplifier ?
Re: Earth ground or both
There seems little point in me starting a thread asking a safety question for it to be merged with somthing totally different.MorseMan wrote: ↑31 Oct 2020, 20:28 I was asked recently can i connect my station to the mains earth.
It may aswell been put under how to brush your pet rabbit.
Re: Ground loops
Doing your own thing with ground rods can be dangerous under certain fault conditions & in the event of local lightening strikes generating high potential between your electrical earth provided by the supplier and diy ground rods,
our local council remove them if they catch you using them in their properties & warn you not to connect it back up,
its best to find out what systen you are on & what you can do with it.
some old properties don't have an earth
i don't use ground rods & bus bars, i have the lowest noise of any local & no ground loops.
W8JI
- Buick Mackane
You chucking your toys, And how to brush your pet rabbit has been merged with how to tickle your parrot with a feather.
Re: Ground loops
Brushing your pet rabbit with a plastic brush or comb can be electrically unsafe, Ion's are stripped & an electrostatic charge will build up.
Given an extended petting session with Thumper, sufficient voltage may build to the extent that both rabbit & owner are vaporized if an earth is touched.
Joking aside, I posted a safety question thread & it got lumped in with something similar but completely different.
It was like putting tomatoes in a fruit salad .
Aaaarrrk Aaaarrrrk who's a pretty boy !
Parrot tickling Is like trout tickling but you don't get your hands wet !!
