Meanwell power supplies question
Re: Meanwell power supplies question
Post by ch25 »
Far from boom. Output is 14V, OVP set to 15V. Pretty safe.
Buick Mackane
Post by Buick Mackane »
ch25 wrote: 29 Oct 2020, 18:11 Far from boom. Output is 14V, OVP set to 15V. Pretty safe.
was a joke lemmy :D You wrote - 14 volts as in negative 14 volts
Every year is getting shorter never seem to find the time
Post by ch25 »
Oh, it was ~ sign, look closer :)
Buick Mackane
ch25 wrote: 29 Oct 2020, 18:50 Oh, it was ~ sign, look closer :)
Your right lemmy, My eyes aren't what they used to be :)
gmham
Call Sign: 108TM154
Post by gmham »
Was sent this link but chap who sent it says his is not suitable for powering his radio gear due to the noise it creates on his radios, uses it as per the article ..model aircraft charging.
https://www.rchelicopterfun.com/dps-600pb-build.html
CH25...any mods required to reduce / eliminate any noise when using your own mate ?
Icom IC746
Cobra 148gtldx mk2
Xiegu G90 HF SDR
John - 108TM154 / 108CO154
Post by ch25 »
I didn't notice any noise or birdies from dps600pb on bands I use - 160-6m so there is nothing to reduce.
Important thing when using switching PS - you must use 3 pole power socket, but it's pretty obvious.
gmham
Call Sign: 108TM154
Post by gmham »
ch25 wrote: 29 Oct 2020, 22:08 I didn't notice any noise or birdies from dps600pb on bands I use - 160-6m so there is nothing to reduce.
Okay thanks guess he was just unlucky with the noise issue . Another good read for anyone planning on modding one.
http://vk2rh.com/computer-power-supply/
Icom IC746
Cobra 148gtldx mk2
Xiegu G90 HF SDR
Post by ch25 »
gmham wrote: 29 Oct 2020, 22:40
I need glasses, no doubt, but where he complains about noise on the bands? I can't find that.
gmham
Call Sign: 108TM154
Post by gmham »
Was talking about the chap who sent me the link in my rchelicopter link who said his was producing severe noise on his radio. But yes the last link I shared certainly never mentioned anything untoward about there use.
Icom IC746
Cobra 148gtldx mk2
Xiegu G90 HF SDR
Post by ch25 »
Ok. I din't need to mod mine against RF noise, because I can't hear any.
I have my station located on country side, with very low noise floor so I would notice it.
Auldgeek
Post by Auldgeek »
I have a HP power supply that can provide over 100A from its 12v line but it will not provide over +13v without modification, although it's reasonably easy. After modification, mine provides about +13.5v.
A simple resistor bridge bypasses the pull up to start requirement & to raise the voltage, I replaced the voltage VR with a fixed resistor. It's also completely noise free across the spectrum.
Can't get more A for your cash. Spend a wee bit more & put it in a case.
Auldgeek - Drew
Amateur Call GM0BRJ
TM Call 108TM144
gmham
Call Sign: 108TM154
Post by gmham »
Hi drew not for sale is it ? Was going to go for one of the ones in the link above mate but just don’t have the tech ability to mod it for the required voltage, lower fan noise etc.
Icom IC746
Cobra 148gtldx mk2
Xiegu G90 HF SDR
Auldgeek
Post by Auldgeek »
Unfortunately not but it really isn't difficult & while it's nice to make it look good, it really isn't required. There's a great thread on converting server power supplies in the home brew section & plenty of info on the web.
Auldgeek - Drew
Amateur Call GM0BRJ
TM Call 108TM144
gmham
Call Sign: 108TM154
Post by gmham »
Okay thanks drew will see if I can pick one up already converted somewhere.
Icom IC746
Cobra 148gtldx mk2
Xiegu G90 HF SDR
