Back on the air - WSPR / ROS / JS8Call / FT8
MrWeetabix
Call Sign: 26TM175
Re: Back on the air - WSPR / ROS / JS8Call / FT8
Post by MrWeetabix »
Just a little update. I changed out the homemade Windom for a home-made end-fed using a 9:1 Balun and some counterpoises. I can now tune all bands, although I seem to have lost 80m, which is an oddity (hoping that improving the Ground system might help). I have recently got the shack in order and I am now able to work two different bands with two different modes at the same time. Over night I ran WSPR on 160m and 10m, the results are below. 10m was on the iMax and Top Band on the end-fed.
10m - iMax2000
160m - HB End-fed (Almost 40m long)
I have been quite impressed with the Top Band performance. I didnt think that I'd be able to get over-the-pond on 5w on Top Band!
MrWeetabix
Call Sign: 26TM175
I am currently trialling the End-fed on 20m to see how it performs (its quite long on 20m and above) and I was pleasantly surprised to see VK pop up on the spotter. Again 5w. I am also running JS8Call on 11m (27.246 USB). I was heard down in 173 division, reunion Isl, which was again quite the surprise. 20m is 5w and 11m is 20w
11m JS8Call
20m WSPR
MrWeetabix
Call Sign: 26TM175
Details on my new end-fed....
A sketch of how its laid out
I was just shy of the ideal length I had researched, so I added a Coil. The spacing is roughly 1inch apart around a 4inch drainpipe former, then just wrapped in black electrical Tape. The coil is probably the reason I can't get 80m, though all other bands tune without issue.
Coil Assembly and Balun
Vertical Section with Bungees to take out any slack from the wire (I'll replace these annually)
MrWeetabix
Call Sign: 26TM175
21OP153 has an interesting setup.... hahaha
Whisky1
Post by Whisky1 »
Nice.
