I'm considering a Sirio 3 element beam. Just wondering if anyone has any experience of them. I'm also interested in SWR plots. The 1.2MHz bandwith quoted by Sirio seems to good to be true.
Sirio SY3 band width
Hams a hobby, CB's for life.
- 14CS06
Re: Sirio SY3 band width
Hello
Here Sirio SY 27-3 and Sirio SY 27-4
- 14CS06
Hello
Sirio SY 27-4 pdf is for 27-3 and 27-4
1.2MHz BW on 27MHz Yagi sounds like garbage antenna to me.
I am currently using the 3 elements on 26.500 and swr 1.1 good up to 500 khz or Ch 7 swr 1.8
- Call Sign: 108SD121
I've used the 4 element, put it up 40 foot had good results in fact great results some even amazing results . I say get one, for the money you can't go wrong get it second hand is even better. Plus you can alter it to suit your needs, I like them for the money I have two going to stack them at some point
