Backup Power
Backup Power
Hi guys does anyone here have backup power in case of a power cut ? If so what setup do you have ? I haven't seen a thread like this so i thought it would be good to helps others. Info would be great for anyone looking in.
Re: Backup Power
I have 1-2 power cuts per year. Never needed backup power.
If so, it would be a few kW diesel generator.
- Call Sign: 45
Re: Backup Power
Not for backup as such but I have used leisure battery in house, also for camping trip whilst using radio coms with a couple 120 watt solar panels for recharging.
In car I carry spare car battery 800 cca which I use to run a amp and ssb radio when mobile or static for a dx on high ground.
I guess both could be used in times of emergency outages.
After a quick Google to look at what others use in outages especially in times of natural disasters so on it seems common in some countries amongst the amateur and radio societies to have battery backup and whilst I hadn't digested it fully theirs a communication plan too some use 333 plan mentioned so will look at that now too.
Likely not adopted in UK but who knows maybe amateur operators have a structured outages plan I don't know.
Some interesting stuff came up when googling using a cb in power outages or disasters.
Interesting stuff
Interesting stuff
Re: Backup Power
Clarke 2k genny running extension lead or split into a plug socket so it feeds the ground floor ring main.
Re: Backup Power
I have a small "Kipor" 4 stroke generator, it is quite small, the size of a large thick brief case.
Bought it some time ago as I was getting a lot of power cuts and I don't live in a remote area.
Not had to use it for about 5 years now, but was very handy when I did get power cuts. Was great to power a lamp and the TV, as for backup heating, I have a portable gas heater.
- Call Sign: 45
Re: Backup Power
Seems very sensible and especially in current climate of energy issues .
I need to do more
I need to do more
- Metradio
- Call Sign: G7HID
Re: Backup Power
In the case of a power cut I think lighting and food would be top of the list, radio usage would be near the bottom...
So candles, torches and a tin opener..
Mike
Mike
- Call Sign: 45
Re: Backup Power
That's a good point
- Call Sign: 26DG01
Re: Backup Power
I have some PV/battery backup (12V) I mainly use for charging things, but I do have a small inverter I use for things like laptop power supplies. My next move is to reconfigure the panels for 48V and get a real inverter, but everything suddenly gets quite expensive.
I did try patching my inverter into the house wiring using a cable with a 13A plug on each end (*after* isolating the consumer unit and unplugging the heavy loads). Even more stupidly, when I connected the cable I had the inverter running first and got a nasty shock when I accidentally touched the (live) plug end.
Sent from my GP300 using DTMF
- Buick Mackane
Re: Backup Power
An irish wolf hound and a tread mill hooked up to a car alternator.
- DX-Digger
- Call Sign: TM205
Re: Backup Power
I have an 800W inverter that I run off a large leisure battery.
I also have a portable gas heater and stove.
I have just aquired a petrol gererator but I now have to consider what petrol to buy as E10 being hygroscopic it can corrode the tank and maybe the carburetta. Im also concerned about how dirty the generated mains signal is so I will have to test it under load.
But if we have a Major power outage I could get by ok.
One thing that would be a nice plus during a power cut, a very low noise floor on my HF radio.
- Call Sign: 45
Re: Backup Power
This is very interesting stuff and I thank the person who posted as it's given me food for thought and led me into other information once I googled some of the questions .slightly off topic but this thread is about back up power for communications however it took me to wondering if in power outages even long term do the amateur society or radio users in UK or Europe or even tm1 have a adopted communications plan ?.
With times ,frequencies duration even ?.
I had spotted this 333 communications plan on some survivalist blog I think but it looked more something specific to survivalist so on stateside .
Is their something recognised in the UK Europe West !.
Whilst I use batteries when portable mobile I never considered if power was out and would need to charge although have solar for camping trips we did .
Never considered e10 fuel issues but wouldn't fuel also be in short supply potentially with no power to pump accept payment .
It does seem that their is a few at least that consider power outages and I'm sure those that don't will soon be robbing the battery off the Mrs car to run the hf in such event or Rob the neighbours leisure battery out his caravan..
Kind of a different aspect to the use of need for use potentially of radio communications here.great being on the outages.
Only kidding ,anyone lend me a genny please. Lol
Re: Backup Power
Yes that's obvious but communication is also very important as it keeps us in touch with loved ones and friends. One thing everyone should have learnt since this all started is that anything can happen at any time and not to take things for granted. The internet has a kill switch that the gov can use any time. Now friends and family might have once laughed at the idea of having a spare cb radio or pmr446 handheld but i bet now with things that has happened its got them thinking. Don't be scared be prepared is the motto that should be making the rounds right now. See we can't let egos get in the way right now we are all in this together no division needed just positive contributions. You make a great point and that is to be ready with at least i'd say a months worth of food and water. Don't rush out and buy all at once just build it up over a few weeks or months period. As someone said having some food and water put aside is living insurance.
- Metradio
- Call Sign: G7HID
Re: Backup Power
Are you professionally paranoid ?
Mike
Mike
