80 Meter Challenge
Werthers
Re: 80 Meter Challenge
Post by Werthers »
G8GGP wrote:
25 Nov 2019, 13:50
Have you thought of one of the ATAS type of antennas in your loft?, it depends on how much height you have got of course. It looks as if you can get a counterpoise out. Guys who use these mobile seem to do pretty well
That sounds very interesting... Whats the height of it?
I've got about 5 foot and a half to play with in height in the loft. I'm going with a mag loop for now but I'm definitely interested in the ATAS as well besides you can't have to many antennas to play with :D
Werthers
Post by Werthers »
40 meter mag loop is now complete, the first thing I noticed was that the receive is a lot better than having the wire antenna, it also tunes up on some other HF bands :D
I should have done this long ago.
mr_m3
Post by mr_m3 »
what design did you use werthers :)
26TM069
M3UBO-----> 2E0FML---->2E0PUC
Werthers
Post by Werthers »
I went for a sorta quad band design with the center loop towards the top and the tuning capacitor at the bottom, it works well on 40 and 20 and tunes 30 meters but haven't heard anything on 30 meters so far. 40 meters and 20 meters has been active all day, I was hoping to see if I could push it up to 17 meters but no luck with 17 meters. 20 meters seems to be its limit from 40 meters. I'm happy with that anyway as 40 and 20 are the main active bands. I'll be working on an 80 meter loop next.
G8GGP
Call Sign: M0AFJ
Post by G8GGP »
Werthers wrote:
29 Nov 2019, 00:39
G8GGP wrote:
25 Nov 2019, 13:50
Sorry for the delay, 1.4 to 1.6M depending on frequency so you should be able to fit this in the loft
ATAS120a
