Hi all.
I’m now setting up my VW T4 campervan for CB, SSB.
It’s a high top camper, so the roof is none metal and too high for a Magmount.
I’m not having the antenna fixed, but to just to attach it for static DX’ing. The storage area in the camper to store the antenna when travelling is 1m width. I bought a stainless CTE Bonnet mount and its fixed to the front bonnet on the far passenger side.
Questions.
I am looking for an the best antenna for DX use that can fit a 1m storage length. I am looking for a longer antenna that can be taken apart for this use?
I have also read that I middle or top load antenna is better due to the location of the mount on the van. Is this correct.
I was looking at a Thunderpole Atom. Any good for my purpose?
Thanks in advance.
Rob.
PS Could I get away with my magmount on the bonnet???
Van antenna help
- KB312
- Call Sign: KB312
Van antenna help
Bob - KB312.
Old to the Hobby but new to the game!
CB, SSB, PMR446 & Network Radio
- Otter
- Call Sign: 26TM439
Re: Van antenna help
I've had two tundepole atoms and a friend has had one. On two different cars we haven't managed to get a decent SWR on any of them. The SWR minimum appears to be on frequency, it's just that it's over 2.
Have a look at a Modulator II (2). It's a decent (not too cheap though) aerial and as it's centre-loaded, it can be split into 2 parts for storage.
- KB312
- Call Sign: KB312
Forum issues here.
I found a quick and good resolution on Zello within minutes.
Bob - KB312.
Talking about the magmount on the bonnet, you could do seeing as it's only being used when parked up. You can buy an adjustable angle adapter so the magmount could be used on a vertical steel surface with the aerial set at 90 degrees. The higher the better though, so the more aerial you can get showing above the bodywork, the better you'll get out.
