Sirio 827 Radials
thundercat
Call Sign: Thundercat
Sirio 827 Radials
Post by thundercat »
Hello All
Ive currently got a Sirio 827 installed but haven't bothered with the rather long Radials (reason being i would have to lift it a fare bit to clear the roof of my house) do i need to install them? what benefits would i get if i did?
What we're dealing with here is a complete lack of respect for the law.
SS3900 Black
Cobra 148 gtl-dx
RM KL203-P Burner
The Modulator Aerial Mobile
Sirio 827
10-10 and we are gone
26-TM-458, 26CT509.
Call Sign: Lemmy
Re: Sirio 827 Radials
Post by ch25 »
Without radials this antenna won't work.
thundercat
ch25 wrote: 07 Feb 2021, 19:51 Without radials this antenna won't work.
No worries I’ll pop them on then, thanks for your reply
SS3900 Black
Cobra 148 gtl-dx
RM KL203-P Burner
Sirio 827
26-TM-458, 26CT509.
The Collector
Post by The Collector »
You could always just put the ones on that don't interfere with your roof tiles etc. You might just lose 2 or three at most then which shouldn't make that much of a difference. Otherwise, hoik the aerial up another couple of feet if you can ;)
thundercat
The Collector wrote: 09 Feb 2021, 18:02 You could always just put the ones on that don't interfere with your roof tiles etc. You might just lose 2 or three at most then which shouldn't make that much of a difference. Otherwise, hoik the aerial up another couple of feet if you can ;)
Good shout, I’ll try that before lifting it
SS3900 Black
Cobra 148 gtl-dx
RM KL203-P Burner
Sirio 827
26-TM-458, 26CT509.
stanogs68
Post by stanogs68 »
Or remove a few roof tiles that are in the way ,just remember put them back if it rains :D
thundercat
stanogs68 wrote: 09 Feb 2021, 19:40 Or remove a few roof tiles that are in the way ,just remember put them back if it rains :D
Living up norf I’d have to be quick 😂😂😂😂
SS3900 Black
Cobra 148 gtl-dx
RM KL203-P Burner
Sirio 827
26-TM-458, 26CT509.
The Collector
If leaving a few 'planes out does the job, just ensure that the empty holes don't lead into the coil or anything, or you'll have to seal them up with some stubby bolts or some silicone sealant ;)
thundercat
The Collector wrote: 10 Feb 2021, 17:05 If leaving a few 'planes out does the job, just ensure that the empty holes don't lead into the coil or anything, or you'll have to seal them up with some stubby bolts or some silicone sealant ;)
I’ve got all but two fitted and looking at the extra height I need to fit the remaining two, I’ll get it with a 5ft pole and mast joiner
SS3900 Black
Cobra 148 gtl-dx
RM KL203-P Burner
Sirio 827
26-TM-458, 26CT509.
bigpimp347
Post by bigpimp347 »
the 827 will work perfectly fine without radials.
they are mostly there for show and to help radiate the signal across the ground
if you mount it at it's correct height, a 5/8th off ground so around 20ft it will use the ground as it's ground plane.
stanogs68
Post by stanogs68 »
thought they was for ssb
thundercat
bigpimp347 wrote: 14 Feb 2021, 19:56 the 827 will work perfectly fine without radials.
Is that 20ft to the tip of the aerial?
SS3900 Black
Cobra 148 gtl-dx
RM KL203-P Burner
Sirio 827
26-TM-458, 26CT509.
Call Sign: Lemmy
Post by ch25 »
You have no idea what you are talking about.
bigpimp347
ch25 wrote: 14 Feb 2021, 21:15
nope of course not..
i've got two 827's (and thirty or more other base antennas) i build my own antennas.
maybe try it and see..
get an 827 remove the useless there for show radials and see what happens..
it still works.. what do you think the coil is for ? , it's matching system as you described in the 'silver rod' post.
the radials, like on a lot of Sirio antennas pretty much do bugger all..
bigpimp347
thundercat wrote: 14 Feb 2021, 20:58
no to the base..
the idea is use an antenna (without radials) a wavelength it is off ground,
so if it's a half wave, then 17ft, a 5/8th then around 20ft.
Cushcraft used the idea years ago on various VHF antennas where line of sight is more important
they just made the antennas ground a matched wavelength below it.
