14 band freq chart
- gmham
- Call Sign: 108TM154
14 band freq chart
Anyone here happen to have a pc copy of the 14 band 24 to 30 mhz band freq chart often seen on eBay they would kindly share ?
Cheers guys.
John
Cheers guys.
John
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- 14CS06
Re: 14 band freq chart
- Otter
- Call Sign: 26TM439
It would be easy enough to knock up in Libreoffice calc but 14 bands is a bit OTT ?
What do you actually want and in what fomat?
- gmham
Thanks Claude that was good if you appreciate that.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- gmham
Your probably right but noticed this one on eBay and liked the look of it just not the price ! Just an easy to easy 26 to 28 mhz one with alphas showing as well as original U.K. 40.
https://www.ebay.co.uk/itm/CB-AMATEUR-H ... 4352025953
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Otter
There's this <link> or I've attached one in a couple of posts down.
- gmham
Okay cheers mate appreciate that. Not sure why I can’t open the version once it has downloaded just says “ freq chart small. Data ? Anyway yep same as that but with the actual U.K. 40 full frq for each ch. sorry to be a pain !
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Otter
The UK frequencies are in the right hand column. I just downlaoded it and it's fine here. It's easy enough to change things around though. I'll zip it up and attach it here.
I've also addd the LibreOffice file so you or anyone else can play with it.
Or I'll make any changes you want.
- gmham
Thats brillant mate thanks so much for that exactly whats required !
P.s just had a quick look and take it will need a few adjustments or am I reading it wrong ?!!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Otter
I don't think it needs adjustments, but if you want it laid out differently I can do that.
- gmham
No probs just noticed from 2x high and 4 x high it’s showing as 26 mhz ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Otter
OOps. I'll fix that
- gmham
Brilliant got it now. Sorry to complain !!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
