Replacing RG8 Mini With Cabnex RG213 Cable.
astradyne
Moderator
Moderator
Post by astradyne »
Hi guys.
Not long since I got a job-lot of stuff off ebay. Included was ten metres of Cabnex RG213 co-ax. I'm currently using RG8 Mini which seems to work well, but I'm toying with the idea of replacing it with the 213 which appears to be a very good quality cable.
Any thoughts quality/performance wise?
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Re: Replacing RG8 Mini With Cabnex RG213 Cable.
Post by MrWeetabix »
at HF (Including CB) I dont think there would be any massive difference, if any :-/
If you use RG8 at VHF or UHF then replacing those runs should produce a better performance return.
However, if the RG8 has been up a while then no harm in swapping it out, as everything has a shelf-life :-)
26TM175. OP: Craig. QTH: Gateshead. Also 163TM175 when mobile in Wales 8)
